[petsc-users] Prometheus vs GAMG for elasticity/plasticity problems
Sanjay Govindjee s_g at berkeley.edu
Mon Jan 27 12:02:02 CST 2014
Thomas,
   It looks like you are asking FEAP to solve the equations multiples
times.  Perhaps you have a nonlinear problem with a Newton loop?
   This is not a fair comparison. Edit your run script to only perform 1
(one) solve "tang,,1" (No Newton loops), then compare.
-sg
On 1/27/14 9:48 AM, Thomas Gross wrote:
> I ran it with:
> -ksp_type cg -pc_type gamg -pc_gamg_type agg -log_summary -ksp_monitor -ksp_view -options_left -mg_levels_ksp_max_it 1 > GAMG_log_max_it.txt
> and
> -ksp_type cg -pc_type gamg -pc_gamg_type agg -log_summary -ksp_monitor -ksp_view -options_left -mg_levels_ksp_type richardson -mg_levels_pc_type sor > GAMG_log_Rich.txt
> (Log files attached)
> However, the solution time did not decrease and I still needed to call KSPSolve 3 times although I had -mg_levels_ksp_max_it 1.
> Best
> Thomas
> On Jan 27, 2014, at 5:53 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Thomas Gross <tgross at ilsb.tuwien.ac.at> writes:
>>> Please find enclosed the log summary for the runs.
>>> I used the following options for Prometheus and GAMG:
>>> Prometheus:
>>> -ksp_type cg -pc_type prometheus -log_summary -ksp_monitor -ksp_view -aggmg_smooths 1 -options_left
>>> GAMG:
>>> -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -log_summary -ksp_monitor -ksp_view -options_left
>> This is a pretty small problem, but switch back to a single smoothing
>> iteration -mg_levels_ksp_max_it 1.  An alternative is
>> -mg_levels_ksp_type richardson -mg_levels_pc_type sor.
>> Note that you are calling KSPSolve 3 times with GAMG, but only once with
>> Prometheus.
Sanjay Govindjee, PhD, PE
Professor of Civil Engineering
Vice Chair for Academic Affairs
779 Davis Hall
University of California
Berkeley, CA 94720-1710
Voice:  +1 510 642 6060
FAX:    +1 510 643 5264
s_g at berkeley.edu
http://www.ce.berkeley.edu/~sanjay
New Books:
Engineering Mechanics of Deformable
Solids: A Presentation with Exercises
http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
http://ukcatalogue.oup.com/product/9780199651641.do
http://amzn.com/0199651647
Engineering Mechanics 3 (Dynamics)
http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
http://amzn.com/3642140181
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/069520be/attachment.html>
