[petsc-users] reusing LU factorization?
Jed Brown jed at jedbrown.org
Wed Jan 29 15:54:07 CST 2014
David Liu <daveliu at mit.edu> writes:
> Not too sure if there's anything I can do about this. Also, I am definately
> willing to use other preconditioners. If direct solvers are expensive, what
> are the cheaper alternatives?
This is a vast question, a bit like asking what kind of "math" is
important for "physics".  If you want help, you'll have to explain more
about your problem, discretization, and regime.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140129/9d6abfbf/attachment.pgp>
