[petsc-users] Problems running ex12.c
Yaakoub El Khamra yelkhamra at gmail.com
Tue Jan 28 10:31:38 CST 2014
If
 ./ex12 -run_type test -dim 3 -refinement_limit 0.0125
-variable_coefficient field    -interpolate 1 -petscspace_order 2
-show_initial -dm_plex_print_fem
is for serial, any chance we can get the options to run in parallel?
Regards
Yaakoub El Khamra
On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin Alexander <
> MAJones2 at mdanderson.org> wrote:
>> *From:* Matthew Knepley [knepley at gmail.com]
>> *Sent:* Friday, January 17, 2014 11:04 AM
>> *To:* Jones,Martin Alexander
>> *Cc:* petsc-users at mcs.anl.gov
>> *Subject:* Re: [petsc-users] Problems running ex12.c
>>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin Alexander <
>>>  These examples all seem to run excepting the following command,
>>> I get the following ouput:
>>> Local function:
>>> ./ex12: symbol lookup error:
>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>> symbol: omp_get_num_procs
>>  This is a build problem, but it should affect all the runs. Is this
>> reproducible? Can you send configure.log? MKL is the worst. If this
>> persists, I would just switch to --download-f-blas-lapack.
> Thanks. I have some advice on options
>   --with-precision=single # I would not use this unless you are doing
> something special, like CUDA
>   --with-clanguage=C++  # I would recommend switching to C, the build is
> much faster
>   --with-mpi-dir=/usr --with-mpi4py=0
>   --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0 --with-fc=0
>   --with-etags=1                # This is unnecessary
> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
> # Here is the problem, see below
>   --download-metis
>   --download-fiat=yes --download-generator --download-scientificpython #
> Get rid of these, they are obsolete
> Your MKL needs another library for the OpenMP symbols. I would recommend
> switching to --download-f2cblaslapack,
> or you can try and find that library.
>   Thanks,
>       Matt
>>    Thanks,
>>       Matt
>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin Alexander <
>>>>  Hi, This is the next error message after configuring and building
>>>> with the triangle package when trying to run ex12
>>>  This is my fault for bad defaults. I will fix. Try running
>>>    ./ex12 -run_type test -refinement_limit 0.0    -bc_type dirichlet
>>> -interpolate 0 -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>>  for a representative run. Then you could try 3D
>>>  or a full run
>>>    ex12 -refinement_limit 0.01 -bc_type dirichlet -interpolate
>>> -petscspace_order 1
>>> -petscspace_order 2
>>>  Let me know if those work.
>>>    Thanks,
>>>       Matt
>>>>   ./ex12
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>>>> Exception,probably divide by zero
>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>>> corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>> function
>>>> [0]PETSC ERROR:       is given.
>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line 531
>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line 63
>>>> /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Signal received!
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-2317-gcd0e7f7
>>>>  GIT Date: 2014-01-15 20:33:42 -0600
>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug named maeda by
>>>> mjonesa Thu Jan 16 17:41:23 2014
>>>> [0]PETSC ERROR: Libraries linked from /home/mjonesa/local/lib
>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 17:38:33 2014
>>>> [0]PETSC ERROR: Configure options --prefix=/home/mjonesa/local
>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>> --download-triangle
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: User provided function() line 0 in  unknown file
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>    On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin Alexander <
>>>>>  Hi, I have downloaded and built the dev version you suggested. I
>>>>> think I need the triangle package to run this particular case. Is there any
>>>>> thing else that appears wrong in what I have done from the error messages
>>>>> below:
>>>>  Great! Its running. You can reconfigure like this:
>>>>    $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>>> --download-triangle
>>>>  and then rebuild
>>>>     make
>>>>  and then rerun. You can load meshes, but its much easier to have
>>>> triangle create them.
>>>>    Thanks for being patient,
>>>>       Matt
>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>> [0]PETSC ERROR: Mesh generation needs external package support.
>>>>> Please reconfigure with --download-triangle.!
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR:
>>>>> mjonesa Thu Jan 16 16:28:20 2014
>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 16:25:53 2014
>>>>> --with-clanguage=c++ --with-c2html=0
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>> [0]PETSC ERROR: main() line 659 in
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>    On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin Alexander <
>>>>>>  Hi. I changed the ENV variable to the correct entry. when I type
>>>>>> make ex12 I get this:
>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$ make
>>>>>> ex12
>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>> -Wno-unknown-pragmas -g   -fPIC
>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>> ex12.c:14:18: fatal error: ex12.h: No such file or directory
>>>>>> compilation terminated.
>>>>>> make: *** [ex12.o] Error 1
>>>>>> Any help of yours is very much appreciated.
>>>>>  Yes, this relates to my 3). This is not going to work for you with
>>>>> the release. Please see the link I sent.
>>>>>     Matt
>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>    On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin Alexander <
>>>>>>>  Thanks!
>>>>>>  You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>     Matt
>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin Alexander <
>>>>>>>>  Now I went to the directory where ex12.c sits and just did a
>>>>>>>> 'make ex12.c' with the following error if this helps?  :
>>>>>>>> make ex12.c
>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>> make: *** No rule to make target
>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>> Stop.
>>>>>>>  1) You would type 'make ex12'
>>>>>>>  2) Either you PETSC_DIR (/home/mjonesa/PETSc/petsc-3.4.3) or
>>>>>>> PETSC_ARCH (linux-gnu-cxx-debug) environment variables
>>>>>>>     do not match what you built. Please send configure.log and
>>>>>>> make.log
>>>>>>>  3) Since it was only recently added, if you want to use the FEM
>>>>>>> functionality, you must use the development version:
>>>>>>>     http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>    Thanks,
>>>>>>>        Matt
>>>>>>>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin Alexander <
>>>>>>>> Hello To Whom it Concerns,
>>>>>>>> I am trying to run the tutorial ex12.c by running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>> but getting the following error:
>>>>>>>> $ bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1
>>>>>>>> laplacian dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>>> Traceback (most recent call last):
>>>>>>>>   File "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15,
>>>>>>>> in <module>
>>>>>>>>     from FIAT.reference_element import default_simplex
>>>>>>>> ImportError: No module named FIAT.reference_element
>>>>>>>> I have removed the requirement of generating the header file (its
>>>>>>>> now all handled in C). I thought
>>>>>>>> I changed the documentation everywhere (including the latest
>>>>>>>> tutorial slides). Can you try running
>>>>>>>> with 'master' (or 'next'), and point me toward the old docs?
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140128/da9d605b/attachment-0001.html>
