[petsc-users] Problems running ex12.c
Fri Jan 17 11:29:11 CST 2014
On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin Alexander <
MAJones2 at mdanderson.org> wrote:
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Friday, January 17, 2014 11:04 AM
> *To:* Jones,Martin Alexander
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Problems running ex12.c
>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin Alexander <
>>  These examples all seem to run excepting the following command,
>> ex12 -run_type test -dim 3 -refinement_limit 0.0125 -variable_coefficient
>> field    -interpolate 1 -petscspace_order 2 -show_initial
>> -dm_plex_print_fem
>> I get the following ouput:
>> ./ex12 -run_type test -dim 3 -refinement_limit 0.0125
>> -variable_coefficient field    -interpolate 1 -petscspace_order 2
>> -show_initial -dm_plex_print_fem
>> Local function:
>> ./ex12: symbol lookup error:
>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>> symbol: omp_get_num_procs
>  This is a build problem, but it should affect all the runs. Is this
> reproducible? Can you send configure.log? MKL is the worst. If this
> persists, I would just switch to --download-f-blas-lapack.
Thanks. I have some advice on options
  --with-precision=single # I would not use this unless you are doing
something special, like CUDA
  --with-clanguage=C++  # I would recommend switching to C, the build is
much faster
  --with-mpi-dir=/usr --with-mpi4py=0
  --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0 --with-fc=0
  --with-etags=1                # This is unnecessary
--with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
# Here is the problem, see below
  --download-metis
  --download-fiat=yes --download-generator --download-scientificpython #
Get rid of these, they are obsolete
Your MKL needs another library for the OpenMP symbols. I would recommend
switching to --download-f2cblaslapack,
or you can try and find that library.
      Matt
>   Thanks,
>       Matt
>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin Alexander <
>>>  Hi, This is the next error message after configuring and building with
>>> the triangle package when trying to run ex12
>>  This is my fault for bad defaults. I will fix. Try running
>>    ./ex12 -run_type test -refinement_limit 0.0    -bc_type dirichlet
>> -interpolate 0 -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>  for a representative run. Then you could try 3D
>>  or a full run
>>    ex12 -refinement_limit 0.01 -bc_type dirichlet -interpolate
>> -petscspace_order 1
>> -petscspace_order 2
>>  Let me know if those work.
>>    Thanks,
>>       Matt
>>>   ./ex12
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>>> Exception,probably divide by zero
>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [0]PETSC ERROR: or see
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>> corruption errors
>>> [0]PETSC ERROR: likely location of problem given in stack below
>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>> function
>>> [0]PETSC ERROR:       is given.
>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line 531
>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line 63
>>> /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Signal received!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-2317-gcd0e7f7
>>>  GIT Date: 2014-01-15 20:33:42 -0600
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug named maeda by mjonesa
>>> Thu Jan 16 17:41:23 2014
>>> [0]PETSC ERROR: Libraries linked from /home/mjonesa/local/lib
>>> [0]PETSC ERROR: Configure run at Thu Jan 16 17:38:33 2014
>>> [0]PETSC ERROR: Configure options --prefix=/home/mjonesa/local
>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>> --download-triangle
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: User provided function() line 0 in  unknown file
>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>    On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin Alexander <
>>>>  Hi, I have downloaded and built the dev version you suggested. I
>>>> think I need the triangle package to run this particular case. Is there any
>>>> thing else that appears wrong in what I have done from the error messages
>>>> below:
>>>  Great! Its running. You can reconfigure like this:
>>>    $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>> --download-triangle
>>>  and then rebuild
>>>     make
>>>  and then rerun. You can load meshes, but its much easier to have
>>> triangle create them.
>>>    Thanks for being patient,
>>>       Matt
>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>> [0]PETSC ERROR: Mesh generation needs external package support.
>>>> Please reconfigure with --download-triangle.!
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR:
>>>> mjonesa Thu Jan 16 16:28:20 2014
>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 16:25:53 2014
>>>> --with-clanguage=c++ --with-c2html=0
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>> [0]PETSC ERROR: main() line 659 in
>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>    On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin Alexander <
>>>>>  Hi. I changed the ENV variable to the correct entry. when I type
>>>>> make ex12 I get this:
>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$ make
>>>>> ex12
>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>> -Wno-unknown-pragmas -g   -fPIC
>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>> ex12.c:14:18: fatal error: ex12.h: No such file or directory
>>>>> compilation terminated.
>>>>> make: *** [ex12.o] Error 1
>>>>> Any help of yours is very much appreciated.
>>>>  Yes, this relates to my 3). This is not going to work for you with
>>>> the release. Please see the link I sent.
>>>>     Matt
>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>    On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin Alexander <
>>>>>>  Thanks!
>>>>>  You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>     Matt
>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin Alexander <
>>>>>>>  Now I went to the directory where ex12.c sits and just did a ‘make
>>>>>>> ex12.c’ with the following error if this helps?  :
>>>>>>> ex12.c
>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>> make: *** No rule to make target
>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>> Stop.
>>>>>>  1) You would type 'make ex12'
>>>>>>  2) Either you PETSC_DIR (/home/mjonesa/PETSc/petsc-3.4.3) or
>>>>>> PETSC_ARCH (linux-gnu-cxx-debug) environment variables
>>>>>>     do not match what you built. Please send configure.log and
>>>>>> make.log
>>>>>>  3) Since it was only recently added, if you want to use the FEM
>>>>>> functionality, you must use the development version:
>>>>>>     http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>    Thanks,
>>>>>>        Matt
>>>>>>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin Alexander <
>>>>>>> Hello To Whom it Concerns,
>>>>>>> I am trying to run the tutorial ex12.c by running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>> but getting the following error:
>>>>>>> $ bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1
>>>>>>> laplacian dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>> Traceback (most recent call last):
>>>>>>>   File "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15,
>>>>>>> in <module>
>>>>>>>     from FIAT.reference_element import default_simplex
>>>>>>> ImportError: No module named FIAT.reference_element
>>>>>>> I have removed the requirement of generating the header file (its
>>>>>>> now all handled in C). I thought
>>>>>>> I changed the documentation everywhere (including the latest
>>>>>>> tutorial slides). Can you try running
>>>>>>> with 'master' (or 'next'), and point me toward the old docs?
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140117/502fad69/attachment-0001.html>
