[petsc-users] -draw_pause not working for all plot windows?
Torquil Macdonald Sørensen torquil at gmail.com
Mon Jan 27 10:17:18 CST 2014
The window appeared and dissapeared, so I just assumed that something was
plotted. But probably not, for the reason you mention.
Thanks!
Best regards
Torquil Sørensen
On 27 January 2014 16:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 27, 2014, at 5:59 AM, Torquil Macdonald Sørensen <torquil at gmail.com>
> wrote:
> > Hi!
> > I'm using todays Petsc git master on Linux and tried:
> > ./prog -mg_coarse_ksp_plot_eigenvalues -draw_pause -1
> > but the plot window simply appears and dissappears at once.
>    Are you sure this command actually does anything? By default the coarse
> solver is an exact solver which cannot compute eigenvalues.
> > On the other hand, if I do
> > ./prog -mg_levels_1_est_ksp_gmres_krylov_monitor -draw_pause -1
> > it works as expected, i.e. I can click on the plot to continue.
> > In addition, the option "-draw_pause" does not appear in the list of
> options when I run
> > ./prog -help
> > It prints a lot of Petsc options, but not -draw_pause.I got the idea of
> trying -draw_pause from here:
> > http://lists.mcs.anl.gov/pipermail/petsc-users/2013-April/017123.html
> > Best regards
> > Torquil Sørensen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/4f8b75c2/attachment-0001.html>
