[petsc-users] -draw_pause not working for all plot windows?
Mon Jan 27 09:57:43 CST 2014
On Jan 27, 2014, at 5:59 AM, Torquil Macdonald Sørensen <torquil at gmail.com> wrote:
> Hi!
> I'm using todays Petsc git master on Linux and tried:
> ./prog -mg_coarse_ksp_plot_eigenvalues -draw_pause -1
> but the plot window simply appears and dissappears at once.
   Are you sure this command actually does anything? By default the coarse solver is an exact solver which cannot compute eigenvalues.
> On the other hand, if I do
> ./prog -mg_levels_1_est_ksp_gmres_krylov_monitor -draw_pause -1
> it works as expected, i.e. I can click on the plot to continue.
> In addition, the option "-draw_pause" does not appear in the list of options when I run
> ./prog -help
> It prints a lot of Petsc options, but not -draw_pause.I got the idea of trying -draw_pause from here:
> http://lists.mcs.anl.gov/pipermail/petsc-users/2013-April/017123.html
> Best regards
> Torquil Sørensen
