[petsc-users] Questions on dense and sparse matrix block
Danyang Su danyang.su at gmail.com
Thu Jan 23 12:45:22 CST 2014
Hi Barry,
This case is a 1D steady state flow with time dependent chemical
reactions. The flow part is solved before the first time step and then
the reaction part will be solved in the time loop.
Part of the matrix for reaction is shown below (png file). Each matrix
block represent a cell. The block is of size 10x10, representing 10
components that will take part in reactions. The blue color is positive
and the red color is negative. This is the first reaction matrix, the
value of the matrix will be changed but the structured will be kept. If
I fill the missing entries (white) with zero to make the sparse block
into dense block, the problem can be solved without any problem.
Please note that the whole matrix is treated as a general sparse matrix.
No block matrix features are used in PETSc at present.
When '-pc_type lu' is used, there will be error showing detected zero
pivot in LU factorization. I can check and exported all the matrices if
needed
Matrix sample
Thanks and regards,
Danyang
On 22/01/2014 6:52 PM, Barry Smith wrote:
>     That is unfortunate.  You may need a good preconditioning strategy. Can you tell us more about your problem? Do you have some fluid variables that couple between cells and then chemistry in each cell.
>    Barry
> On Jan 22, 2014, at 8:14 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> with option '-pc_type lu', I got an error message after some steps.
>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [0]PETSC ERROR: Detected zero pivot in LU factorization:
>> see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
>> [0]PETSC ERROR: Zero pivot row 5 value 7.63923e-045 tolerance 2.22045e-014!
>> Danyang
>> On 22/01/2014 5:28 PM, Barry Smith wrote:
>>>    With a 1d problem likely the sparse format and -pc_type lu is the way to go.
>>>    Barry
>>> On Jan 22, 2014, at 7:15 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>> On 22/01/2014 4:32 PM, Barry Smith wrote:
>>>>>    What ODE integrator are you using? Your own? One in PETSc?
>>>> I use my own integrator and PETSc is used as KSP solver. I may need to test more cases especially 2D cases to see the behavior of dense format and sparse format.
>>>>>     You could just use -pc_type lu and the sparse format right? Or is that too slow?
>>>>>     Barry
>>>>>    Jed and Emil,  do we have any integrators that keep the time-step small due to slow convergence of Newton in TS?
>>>>> On Jan 22, 2014, at 5:05 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>>>> On 22/01/2014 1:42 PM, Barry Smith wrote:
>>>>>>>     Linear solvers based on ILU will behave very differently when extra zeros are kept in the matrix; they generally converge much faster because the ILU behaves more like an LU (especially in 1d).   So first run one 1 process with dense and sparse formats and -pc_type lu;  do they behave differently? (they pretty much shouldn’t).
>>>>>> It does not behave differently with the option '-pc_type lu'.
>>>>>>>    Next run the sparse format version with -ksp_monitor_true_residual and see how the solver is converging compared to the dense format version.
>>>>>> The converging is quite different.
>>>>>> ---Sparse format
>>>>>>   0 KSP preconditioned resid norm 5.242977405897e-004 true resid norm 3.927123490361e-006 ||r(i)||/||b|| 1.000000000000e+000
>>>>>>   1 KSP preconditioned resid norm 6.118580743238e-006 true resid norm 2.917502282301e-008 ||r(i)||/||b|| 7.429107562985e-003
>>>>>>   2 KSP preconditioned resid norm 9.271130393116e-007 true resid norm 9.649272009380e-009 ||r(i)||/||b|| 2.457083927476e-003
>>>>>>   3 KSP preconditioned resid norm 5.812641606714e-009 true resid norm 4.073757311146e-011 ||r(i)||/||b|| 1.037338734355e-005
>>>>>>   4 KSP preconditioned resid norm 1.992914862465e-010 true resid norm 1.261636843933e-012 ||r(i)||/||b|| 3.212623303112e-007
>>>>>>   5 KSP preconditioned resid norm 1.422122839379e-012 true resid norm 2.393761421284e-014 ||r(i)||/||b|| 6.095457469466e-009
>>>>>> ---Dense format
>>>>>>   0 KSP preconditioned resid norm 2.948306125658e+000 true resid norm 2.436662454678e-004 ||r(i)||/||b|| 1.000000000000e+000
>>>>>>   1 KSP preconditioned resid norm 9.798852520841e-015 true resid norm 1.267168968393e-018 ||r(i)||/||b|| 5.200428832315e-015
>>>>>> The convergence seems difficult for the sparse format and the number of outer newton iteration is usually much larger than dense format.
>>>>>> So the time step cannot increase due to this.
>>>>>> Thanks,
>>>>>> Danyang
>>>>>>>     Barry
>>>>>>> On Jan 22, 2014, at 2:11 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>>>>>> Dear All,
>>>>>>>> I have a reactive transport problem that use block matrices. Each block can be dense with a lot of zero entries or sparse without zero entries. The model has been tested for a 1D reactive transport problem. When dense block is used, it works well and time step can be increased gradually to reach a maximum time step, but when sparse block is used, the time step remains at a small value. I checked the entries for both dense blocks and sparse blocks (A), they have the same non-zero entries. With the same RHS (b), the solution (X) is a little different, but seems acceptable. The first matrix with both dense blocks and sparse blocks has been attached. The matrix is exported in matrix market exchange format (.mtp).
>>>>>>>> I wonder if this is caused by the outer newton iteration or the solver as this is not a general problem. This problem only occurs in some cases.
>>>>>>>> Does anyone run into this problem before?
>>>>>>>> Thanks and regards,
>>>>>>>> Danyang
>>>>>>>> <a_reactran_rt_1_dense.mtp><a_reactran_rt_1_dense.PNG><b_reactran_rt_1_dense.txt><x_reactran_rt_1_dense.txt><a_reactran_rt_1_sparse.mtp><a_reactran_rt_1_sparse.PNG><b_reactran_rt_1_sparse.txt><x_reactran_rt_1_sparse.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140123/d44544df/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140123/d44544df/attachment-0001.png>
