[petsc-users] Problems running ex12.c
Thu Jan 16 15:58:49 CST 2014
On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin Alexander <
MAJones2 at mdanderson.org> wrote:
>  Thanks!
You built with PETSC_ARCH=arch-linux2-cxx-debug
   Matt
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Thursday, January 16, 2014 3:31 PM
> *To:* Jones,Martin Alexander
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Problems running ex12.c
>    On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin Alexander <
>>  Now I went to the directory where ex12.c sits and just did a ‘make
>> ex12.c’ with the following error if this helps?  :
>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$ make
>> ex12.c
>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>> such file or directory
>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>> make: *** No rule to make target
>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>> Stop.
>  1) You would type 'make ex12'
>  2) Either you PETSC_DIR (/home/mjonesa/PETSc/petsc-3.4.3) or PETSC_ARCH (
> linux-gnu-cxx-debug) environment variables
>     do not match what you built. Please send configure.log and make.log
>  3) Since it was only recently added, if you want to use the FEM
> functionality, you must use the development version:
>     http://www.mcs.anl.gov/petsc/developers/index.html
>    Thanks,
>        Matt
>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>> *Sent:* Thursday, January 16, 2014 2:48 PM
>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin Alexander <
>> Hello To Whom it Concerns,
>> I am trying to run the tutorial ex12.c by running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>> dim order dim 1 laplacian dim order dim 1 boundary
>> src/snes/examples/tutorials/ex12.h'
>> but getting the following error:
>> $ bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1
>> laplacian dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>> Traceback (most recent call last):
>>   File "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15, in
>> <module>
>>     from FIAT.reference_element import default_simplex
>> ImportError: No module named FIAT.reference_element
>> I have removed the requirement of generating the header file (its now all
>> handled in C). I thought
>> I changed the documentation everywhere (including the latest tutorial
>> slides). Can you try running
>> with 'master' (or 'next'), and point me toward the old docs?
>>   Thanks,
>>     Matt
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140116/8a2befa0/attachment.html>
