[petsc-users] request related to DMPlexComputeCellGeometryFVM
Thu Jan 16 14:54:53 CST 2014
On Thu, Jan 16, 2014 at 2:36 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Hello,
>          I have a request related to cell geometry for FVM. I am
> working on implementing a solver for coupled electron hole transport
> problem in a semiconductor.
> For the descretization (see the link [1] below), i want to use the FVM
> which uses voronoi box around each node as the control volume. Current
> implementation of the ComputeCellGeometry, provide the centroid of the
> cell.
> Can i request for functionality similar to ComputeCellGeometry, which
> on call returns, the orthocenter and the area perpendiclar to each
> edge for flux computation ?
1) I had to lookup orthocenter and I got this:
http://www.mathopenref.com/triangleorthocenter.html
     which only defines it in 2D, and says it can be outside the triangle.
This does not sound promising.
     If you explain the calculation to me, I can help you implement it.
2) I do give back the edge area if you pass in the edge. Have you looked at
TS ex12? It shows me
    using this routine.
I will take a look at the discretization and see if I can understand it (I
see they say there is a problem with
obtuse elements).
   Matt
> Or any suggested references to look for geometry related routines.
> [1] http://www.iue.tuwien.ac.at/phd/triebl/node30.html
> Thanks
> Reddy
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140116/144fb896/attachment.html>
