[petsc-users] DMPlexCreateGmsh
Thu Jan 16 14:34:33 CST 2014
On Thu, Jan 16, 2014 at 2:17 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com>wrote:
> Hello,
>         Gmsh does not output mesh in exodus format. I tried hard to
> look for an open source mesher which i can use, i ended up with gmsh.
> If there is a better alternative i can switch.
You could use --download-ctetgen which also meshes in 3D. I am not sure
what else Gmsh provides.
> Currently i pre process the gmsh file in my fortran code before i
> create a dm object via createFromCellList.
> Is there an opensource mesh converter available which can take gmsh to
> exoduss, i could not find one. I tried writing one but the problem is,
> i have to first form all the edges/facets in the mesh and map them to
> the boundary before i can create the sidesets for the exodus.
This at least is easy. If you have a cell-vertex mesh, you can call
  DMPlexInterpolate(dm, &idm);
and get the edges/faces.
> So, if it is possible, i will prefer to read my mesh via
> DMPLexcreateGmsh otherwise i can continue to use my code.
We can try. What will probably happen is that the reader will be able to
handle
exactly what you need since the full format is a little crazy.
      Matt
> Thank you All
> Reddy
> On Thu, Jan 16, 2014 at 8:28 AM, Jed Brown <jed at jedbrown.org> wrote:
> > Matthew Knepley <knepley at gmail.com> writes:
> >> On Sun, Jan 12, 2014 at 7:37 PM, Gorman, Gerard J
> >> <g.gorman at imperial.ac.uk>wrote:
> >>>  Hi Matt
> >>>  First - really sorry for having inflicted this on you. I agree that
> >>> there are many problems with the format and it’s not like the world
> needs a
> >>> new file format. I only happened to use it for a case where there was
> an
> >>> existing toolchain…which I’m now rewriting anyhow.
> >>>  What is your current least detested file format for FEM that plays
> >>> nicely with DMPlex? Exodus II?
> >> ExodusII we can read, and it maintains all the markers correctly, etc.
> It
> >> is currently my favorite.
> > CGNS is another alternative that is implemented (though less mature in
> > PETSc).  Note that CGNS is more typically finite volume CFD oriented,
> > though it can also be used for FEM.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140116/773adbd0/attachment.html>
