[petsc-users] PETSc/VC12 compilation
Abilash Nair abilash at gmail.com
Tue Jan 14 14:18:21 CST 2014
Thank you Satish for that input. I had a successful build and test on
cygwin, However I notice two things: a) when I make a test case, say ex1,
the make calls gcc; instead of win32fe cl and b) The petsc archive created
is a ".a" extension, my assumption was that a ".lib" would be generated in
this exercise. In any case, I am unable to build "ex1" as a project in
VS2012, is there some flags that I need to play around with?
I send the config, make and test logs with this email.
Thank you greatly,
Abilash.
On Tue, Jan 14, 2014 at 11:37 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Try adding configure option: --with-cxx='win32fe cl'
> Satish
> On Tue, 14 Jan 2014, Abilash Nair wrote:
> > Hello all,
> > I am trying to build petsc to use as a library on a visual C++ project.
> > I configured the petsc (v3.4.3) with VC++ 2012 under the shell provided
> by
> > VC2012 with the following command (in cygwin):
> > ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1 --with-fc=0
> > --with-cc='win32fe cl' --with-debugging=1
> > then I did a make all; make test while still in cygwin. I have sent the
> log
> > file outputs from these commands. As the files show, I am able to make
> with
> > no errors at all, however I am unable to execute any of the tests (error
> > being that a libstcc++.lib not found).
> > I hope you would be able to suggest a path forward.
> > Thanks!
> > Abilash.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140114/99395403/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140114/99395403/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140114/99395403/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140114/99395403/attachment-0005.obj>
