[petsc-users] PETSc/VC12 compilation
Tue Jan 14 10:37:26 CST 2014
Try adding configure option: --with-cxx='win32fe cl'
Satish
On Tue, 14 Jan 2014, Abilash Nair wrote:
> Hello all,
> I am trying to build petsc to use as a library on a visual C++ project.
> I configured the petsc (v3.4.3) with VC++ 2012 under the shell provided by
> VC2012 with the following command (in cygwin):
> ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1 --with-fc=0
> --with-cc='win32fe cl' --with-debugging=1
> then I did a make all; make test while still in cygwin. I have sent the log
> file outputs from these commands. As the files show, I am able to make with
> no errors at all, however I am unable to execute any of the tests (error
> being that a libstcc++.lib not found).
> I hope you would be able to suggest a path forward.
> Thanks!
> Abilash.
