[petsc-users] Reductions in various vector and matrix kernels
R. Oğuz Selvitopi roguzsel at gmail.com
Tue Jan 7 14:57:23 CST 2014
It is a great convenience to have one line of bash script to change to
debug or optimized build using PETSC_ARCH.
I have done this at my computer and everything is fine.
It seems PETSc performs additional checks that require extra communication
in VecAXPY/VecAYPX as well as in MatMultTranspose when built with debug
option.
It does not perform any communication in the kernels I have mentioned in
the optimized build.
On Mon, Jan 6, 2014 at 8:03 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> You should be able to grab PETSC_ARCH/conf/reconfigure_PETSC_ARCH.py
> from the current install [on the supercomputer] - modify the required
> options - and rerun this script to get an equivalent build.
> Satish
> On Sat, 4 Jan 2014, Barry Smith wrote:
> >   You need to build PETSc twice in total. Use two different PETSC_ARCH
> for example arch-debug and arch-opt  then just switch between the
> PETSC_ARCH depending on what you are doing.
> >    If you have any trouble installing PETSc just send the configure.log
> and make.log to petsc-maint at mcs.anl.gov and we’ll help you get it
> installed.
> >    Barry
> > On Jan 4, 2014, at 6:18 PM, R. Oğuz Selvitopi <roguzsel at gmail.com>
> wrote:
> > > And if I want to run my code without debugging mode on, I have to
> build PETSc from the beginning with the corresponding configure options,
> right?
> > > That is some headache for me, as I am using PETSc on a supercomputer
> and it is built with the default option, where debug mode is on.
> > > On Sun, Jan 5, 2014 at 1:52 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >   The debug version does extra reductions for error checking, you
> should never look at -log_summary with a debug build.
> > >    Normally MatMult() for MPIAIJ matrices has nearest neighbor
> communication so neither MatMult() or MatMultTranspose() has global
> reductions but if some scatters involve all entries then VecScatter does
> use global reductions in those cases.  You could run a slimmed down run on
> 2 process with one process in the debugger and put a break point in
> MPI_Allreduce() and MPI_Reduce() to see when it is being triggered inside
> the MatMultTranspose(). Use -start_in_debugger -debugger_nodes 0
> > >    Barry
> > > On Jan 4, 2014, at 1:32 PM, R. Oğuz Selvitopi <roguzsel at gmail.com>
> wrote:
> > > > Hello,
> > > > I am trying to understand the output generated by PETSc with
> -log_summary option.
> > > > Using PetscLogStageRegister/PetscLogStagePush/PetscLogStagePop I
> want to find out if there exists unnecessary communication in my code.
> > > > My problem is with understanding the number of reductions performed.
> > > > I have a solver whose stages are logged, and in the summary stages
> output, I get
> > > > Summary of Stages:   ----- Time ------  ----- Flops -----  ---
> Messages ---  -- Message Lengths --  -- Reductions --
> > > >                                  Avg     %Total     Avg     %Total
> counts   %Total     Avg         %Total   counts   %Total
> > > > 4:          Solver: 6.5625e-04   4.3%  4.2000e+02  59.7%  1.600e+01
>  23.2%  3.478e+00       14.5%  8.000e+00   5.3%
> > > > where it seems I have 8 reduction operations performed. But in the
> details of the stage events, I get:
> > > > --- Event Stage 4: Solver
> > > > Event                Count      Time (sec)     Flops
>             --- Global ---  --- Stage ---   Total
> > > >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
> len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> > > > MatMult                      1 1.0 1.2207e-04 1.8 4.10e+01 4.1
> 8.0e+00 1.5e+01 0.0e+00  1 16 12  7  0  15 27 50 50  0     1
> > > > MatMultTranspose       1 1.0 1.2112e-04 1.0 4.60e+01 3.8 8.0e+00
> 1.5e+01 2.0e+00  1 18 12  7  1  18 30 50 50 25     1
> > > > VecDot                       3 1.0 2.6989e-04 1.2 2.90e+01 2.6
> 0.0e+00 0.0e+00 3.0e+00  2 12  0  0  2  36 20  0  0 38     0
> > > > VecSet                       2 1.0 8.1062e-06 1.5 0.00e+00 0.0
> 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
> > > > VecAXPY                   2 1.0 3.7909e-05 1.3 2.00e+01 2.0 0.0e+00
> 0.0e+00 0.0e+00  0  9  0  0  0   5 15  0  0  0     2
> > > > VecAYPX                   1 1.0 5.0068e-06 1.2 1.00e+01 1.7 0.0e+00
> 0.0e+00 0.0e+00  0  5  0  0  0   1  8  0  0  0     6
> > > > VecScatterBegin         2 1.0 7.2956e-05 2.4 0.00e+00 0.0 1.6e+01
> 1.5e+01 0.0e+00  0  0 23 14  0   6  0100100  0     0
> > > > VecScatterEnd           2 1.0 9.5129e-05 2.2 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0  10  0  0  0  0     0
> > > > It seems there are only 5 reductions.
> > > > But when I detail my log stages, it shows up VecAXPY/VecAYPX
> operations require reductions as well (I have two VecAXPY and a single
> VecAYPX, so 5+3 = 8).
> > > > (Whose logs I have not included here).
> > > > Normally these two operations should not require any reductions at
> all, as opposed to VecDot.
> > > > Do VecAXPY/VecAYPX require reductions? Is it because PETSc is
> compiled with the debugging option so that it performs additional checks
> that perform reductions?
> > > > Which is the correct number of reductions in above statistics, 5 or
> 8?
> > > > Moreover, why does MatMult require no reduction whereas
> MatMultTranspose requires two of them?
> > > > Thanks in advance.
> > > Oguz.
Oguz.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140107/93bed475/attachment.html>
