[petsc-users] Reductions in various vector and matrix kernels
Mon Jan 6 12:03:42 CST 2014
You should be able to grab PETSC_ARCH/conf/reconfigure_PETSC_ARCH.py
from the current install [on the supercomputer] - modify the required
options - and rerun this script to get an equivalent build.
Satish
On Sat, 4 Jan 2014, Barry Smith wrote:
>   You need to build PETSc twice in total. Use two different PETSC_ARCH for example arch-debug and arch-opt  then just switch between the PETSC_ARCH depending on what you are doing.
>    If you have any trouble installing PETSc just send the configure.log and make.log to petsc-maint at mcs.anl.gov and we’ll help you get it installed.
>    Barry
> On Jan 4, 2014, at 6:18 PM, R. Oğuz Selvitopi <roguzsel at gmail.com> wrote:
> > And if I want to run my code without debugging mode on, I have to build PETSc from the beginning with the corresponding configure options, right?
> > That is some headache for me, as I am using PETSc on a supercomputer and it is built with the default option, where debug mode is on.
> > On Sun, Jan 5, 2014 at 1:52 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   The debug version does extra reductions for error checking, you should never look at -log_summary with a debug build.
> >    Normally MatMult() for MPIAIJ matrices has nearest neighbor communication so neither MatMult() or MatMultTranspose() has global reductions but if some scatters involve all entries then VecScatter does use global reductions in those cases.  You could run a slimmed down run on 2 process with one process in the debugger and put a break point in MPI_Allreduce() and MPI_Reduce() to see when it is being triggered inside the MatMultTranspose(). Use -start_in_debugger -debugger_nodes 0
> >    Barry
> > On Jan 4, 2014, at 1:32 PM, R. Oğuz Selvitopi <roguzsel at gmail.com> wrote:
> > > Hello,
> > > I am trying to understand the output generated by PETSc with -log_summary option.
> > > Using PetscLogStageRegister/PetscLogStagePush/PetscLogStagePop I want to find out if there exists unnecessary communication in my code.
> > > My problem is with understanding the number of reductions performed.
> > > I have a solver whose stages are logged, and in the summary stages output, I get
> > > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
> > >                                  Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
> > > 4:          Solver: 6.5625e-04   4.3%  4.2000e+02  59.7%  1.600e+01  23.2%  3.478e+00       14.5%  8.000e+00   5.3%
> > > where it seems I have 8 reduction operations performed. But in the details of the stage events, I get:
> > > --- Event Stage 4: Solver
> > > Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
> > >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> > > MatMult                      1 1.0 1.2207e-04 1.8 4.10e+01 4.1 8.0e+00 1.5e+01 0.0e+00  1 16 12  7  0  15 27 50 50  0     1
> > > MatMultTranspose       1 1.0 1.2112e-04 1.0 4.60e+01 3.8 8.0e+00 1.5e+01 2.0e+00  1 18 12  7  1  18 30 50 50 25     1
> > > VecDot                       3 1.0 2.6989e-04 1.2 2.90e+01 2.6 0.0e+00 0.0e+00 3.0e+00  2 12  0  0  2  36 20  0  0 38     0
> > > VecSet                       2 1.0 8.1062e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
> > > VecAXPY                   2 1.0 3.7909e-05 1.3 2.00e+01 2.0 0.0e+00 0.0e+00 0.0e+00  0  9  0  0  0   5 15  0  0  0     2
> > > VecAYPX                   1 1.0 5.0068e-06 1.2 1.00e+01 1.7 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   1  8  0  0  0     6
> > > VecScatterBegin         2 1.0 7.2956e-05 2.4 0.00e+00 0.0 1.6e+01 1.5e+01 0.0e+00  0  0 23 14  0   6  0100100  0     0
> > > VecScatterEnd           2 1.0 9.5129e-05 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  10  0  0  0  0     0
> > > It seems there are only 5 reductions.
> > > But when I detail my log stages, it shows up VecAXPY/VecAYPX operations require reductions as well (I have two VecAXPY and a single VecAYPX, so 5+3 = 8).
> > > (Whose logs I have not included here).
> > > Normally these two operations should not require any reductions at all, as opposed to VecDot.
> > > Do VecAXPY/VecAYPX require reductions? Is it because PETSc is compiled with the debugging option so that it performs additional checks that perform reductions?
> > > Which is the correct number of reductions in above statistics, 5 or 8?
> > > Moreover, why does MatMult require no reduction whereas MatMultTranspose requires two of them?
> > > Thanks in advance.
> > Oguz.
