[petsc-users] Columnwise and 2D partitioning for matrices that have irregular sparsity patterns
Thu Jan 2 21:41:16 CST 2014
"R. Oğuz Selvitopi" <roguzsel at gmail.com> writes:
> Hello,
> Is it possible to partition a parallel matrix in PETSc as follows:
> A B C
> D E F
> G H I
> The blocks A-D-G belong to processor 0 (A is the diagonal block, D and
> G are off-diagonal blocks)
> The blocks B-E-H belong to processor 1 (E is the diagonal block, B and
> H are off-diagonal blocks)
> The blocks C-F-I belong to processor 2 (I is the diagonal block, C and
> F are off-diagonal blocks)
Assemble the transpose, then either use MatMultTranspose or
MatCreateTranspose.
> Or, is it possible to have nine processors and each has a block of the
> matrix above? Block A belongs to processor 0, block B belongs to
> processor 1, and so on...
Not with sparse matrices (except using MatShell, in which case you are
responsible for the implementation).  You can do it for dense matrices
(see MatElemental).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140102/90c8f308/attachment.pgp>
