[petsc-users] DMDA questions
Xiangdong epscodes at gmail.com
Fri Feb 28 16:14:21 CST 2014
On Fri, Feb 28, 2014 at 5:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Feb 28, 2014 at 2:10 PM, Xiangdong <epscodes at gmail.com> wrote:
>> On Fri, Feb 28, 2014 at 4:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Feb 28, 2014, at 3:27 PM, Xiangdong <epscodes at gmail.com> wrote:
>>> > On Fri, Feb 28, 2014 at 4:21 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Fri, Feb 28, 2014 at 1:16 PM, Xiangdong <epscodes at gmail.com> wrote:
>>> > If I assembly the matrix with MatSetValuesStencil and use
>>> KspSetOpreators for Ksp, do I need to call KspSetDM first?
>>> > No
>>> > What is the key difference or advantage of using
>>> KspSetComputeOperators against KspSetOperators?
>>> > With the later, you have to manage creating and preallocating the
>>> matrix.
>>> > If I use DMCreateMatrix and MatSetValuesStencil, I do not need to
>>> preallocate the matrix.
>>>    Correct.
>>>    The SetComputeOperators and KSPSetDM is useful if you wish to use
>>> multigrid on system since PCMG will call your compute operators function on
>>> each level for you automatically. See src/ksp/ksp/examples/tutorials/
>>> ex25.c ex28.c ex29.c ex31.c ex32.c ex34.c ex45.c ex50.c   If you are just
>>> solving the one system and not using multigrid then there is no particular
>>> advantage in SetComputeOperators and KSPSetDM
>> If I want to use multigrid as a preconditioner, I have to call
>> KspSetComputeOperators. Is this true?
> No, you can always do everything by hand, but that call simplifies the job.
Does "by hand" mean providing the routines for assembling the matrix at
different level/size manually?
Xiangdong
>    Matt
>> Thank you.
>> Xiangdong
>>>    Barry
>>> > Xiangdong
>>> >    Matt
>>> > Thanks you.
>>> > Xiangdong
>>> > On Tue, Feb 25, 2014 at 4:24 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> > Xiangdong <epscodes at gmail.com> writes:
>>> > > I am not clear about this. In this example, where is the format
>>> declaration
>>> > > (e.g.,mpiaij) of Mat jac? Why is this mat jac always distributed in
>>> > > a compatible way as the DM vectors?
>>> > src/ksp/ksp/examples/tutorials/ex25.c calls KSPSetDM and sets functions
>>> > to assemble the matrices and right hand side.  Those objects are
>>> created
>>> > internally (you can use -dm_mat_type sbaij if you like) and the user
>>> > doesn't have to see them.
>>> > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140228/80e6883b/attachment.html>
