[petsc-users] DMDA questions
Fri Feb 28 16:11:07 CST 2014
On Fri, Feb 28, 2014 at 2:10 PM, Xiangdong <epscodes at gmail.com> wrote:
> On Fri, Feb 28, 2014 at 4:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 28, 2014, at 3:27 PM, Xiangdong <epscodes at gmail.com> wrote:
>> > On Fri, Feb 28, 2014 at 4:21 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Feb 28, 2014 at 1:16 PM, Xiangdong <epscodes at gmail.com> wrote:
>> > If I assembly the matrix with MatSetValuesStencil and use
>> KspSetOpreators for Ksp, do I need to call KspSetDM first?
>> > No
>> > What is the key difference or advantage of using KspSetComputeOperators
>> against KspSetOperators?
>> > With the later, you have to manage creating and preallocating the
>> matrix.
>> > If I use DMCreateMatrix and MatSetValuesStencil, I do not need to
>> preallocate the matrix.
>>    Correct.
>>    The SetComputeOperators and KSPSetDM is useful if you wish to use
>> multigrid on system since PCMG will call your compute operators function on
>> each level for you automatically. See src/ksp/ksp/examples/tutorials/
>> ex25.c ex28.c ex29.c ex31.c ex32.c ex34.c ex45.c ex50.c   If you are just
>> solving the one system and not using multigrid then there is no particular
>> advantage in SetComputeOperators and KSPSetDM
> If I want to use multigrid as a preconditioner, I have to call
> KspSetComputeOperators. Is this true?
No, you can always do everything by hand, but that call simplifies the job.
   Matt
> Thank you.
> Xiangdong
>>    Barry
>> > Xiangdong
>> >    Matt
>> > Thanks you.
>> > Xiangdong
>> > On Tue, Feb 25, 2014 at 4:24 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > Xiangdong <epscodes at gmail.com> writes:
>> > > I am not clear about this. In this example, where is the format
>> declaration
>> > > (e.g.,mpiaij) of Mat jac? Why is this mat jac always distributed in
>> > > a compatible way as the DM vectors?
>> > src/ksp/ksp/examples/tutorials/ex25.c calls KSPSetDM and sets functions
>> > to assemble the matrices and right hand side.  Those objects are created
>> > internally (you can use -dm_mat_type sbaij if you like) and the user
>> > doesn't have to see them.
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140228/5ee205fb/attachment-0001.html>
