[petsc-users] From 1D to 3D problem ? Unstructured mesh ?
Derek Gaston friedmud at gmail.com
Fri Feb 21 23:17:18 CST 2014
The phase-field system developed by Michael Tonks (copied on this email)
will be part of the open-source release of MOOSE (hopefully by the end of
next week).  Feel free to contact either myself or Mike for more
information while we all wait...
In the meantime you can also check out some of the youtube videos of MOOSE
in action (the phase-field system is in use in these videos in the
microstructure models):
http://www.youtube.com/watch?v=0oz8FD3H52s
http://www.youtube.com/watch?v=4xTfQxpGAI4
http://www.youtube.com/watch?v=V-2VfET8SNw
Derek
On Fri, Feb 21, 2014 at 5:33 PM, Jed Brown <jed at jedbrown.org> wrote:
> Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> > Hi all,
> > Recently I have implemented a 1D problem of coupled diffusion equations
> > using PETSc. I did it using finite differences for diffusion terms and
> > F(t,U,U_t) = 0. It works pretty well with ARKIMEX3. I get a nice timestep
> > variation and all boundary conditions work well.
> > Now I would like to move to 3D problems to simulate the diffusion and
> > interaction of species in a "real material". By real material I mean a
> > material made of subregions with internal surfaces where species could
> > recombine (means Dirichlet). These subregions are distributed in a
> > complicated manner, ie not cartesian. A good picture of this would be a
> > polycrystal (see attachment to get an idea). Each crystal has a different
> > orientation and the boundary between two small crystals forms an internal
> > surface.
> > I have several questions on how to implement this:
> > 1) Since, the problem will not be solved in a cartesian mesh, should I
> use
> > unstructured meshes ? If so, how can this unstructured mesh can be
> > generated ( I have no experience with unstructured meshes. I always work
> in
> > 1D).
> Are you intending to mesh the boundaries of the crystals?  Will you be
> dynamically remeshing?  (That is very complicated and expensive in 3D.)
> What formulation will you be using for grain boundary evolution?
> I think you should check out phase field models, such as the publication
> below.  Perhaps check out the paper below.  The framework (MOOSE) used
> for this publication should be released open source on github next week
> (check https://github.com/idaholab/).  I don't know if Marmot, the
> phase-field component, will be open source any time soon, but they are
> typically happy to collaborate.  MOOSE uses PETSc for solvers, but
> provides a higher level interface.
> @article{tonks2012object,
>   title={An object-oriented finite element framework for multiphysics
> phase field simulations},
>   author={Tonks, M.R. and Gaston, D. and Millett, P.C. and Andrs, D. and
> Talbot, P.},
>   journal={Computational Materials Science},
>   volume={51},
>   number={1},
>   pages={20--29},
>   year={2012},
>   publisher={Elsevier}
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140221/b2877bac/attachment.html>
