[petsc-users] partial stencil in DMDA?
Fischer, Greg A. fischega at westinghouse.com
Fri Feb 21 14:42:36 CST 2014
Barry,
If I'm interpreting correctly, the 2nd case would work fine for me. However, perhaps I was previously over-complicating the problem. Could I not just:
1. create a DMDA
2. create a global vector with DOF=1
3. call VecDuplicateVecs() against the DOF=1 global vector for my other ~100 DOFs
and then independently manage the duplicated vectors with the array returned by VecDuplicateVecs()?
Also, when you mentioned changes to DMSetUp_DA_2D() in your original reply, you're suggesting that I could modify the PETSc source code, not use some pre-existing interface, correct?
Greg
>-----Original Message-----
>From: Barry Smith [mailto:bsmith at mcs.anl.gov]
>Sent: Friday, February 21, 2014 3:20 PM
>To: Fischer, Greg A.
>Cc: petsc-users at mcs.anl.gov
>Subject: Re: [petsc-users] partial stencil in DMDA?
>   Greg,
>     The general mechanism for moving elements of vector between processes
>is with VecScatterCreate() and VecScatterBegin/End() with it you can indicate
>exactly what values are to move and to where, but it is all based on "one
>dimension" indexing into the vector.
>    DMDA provides a subset of communication for "structured meshes"
>(essentially 1,2, 3 dimensional arrays split among processes with horizontal
>and vertical cuts). It is pretty much all or nothing in terms of communicating
>neighbor information.
>    VecCreateGhost() uses the VecScatter mechanism to set up a SINGLE
>communication pattern between a Vec and its ghosted partner Vec.
>   Based on your email: "However, when communicating ghost values, not all
>of those degrees of freedom should be exchanged at once." it sounds like
>you need several (many) communication patterns requiring different ghost
>entries in each.
>1) The hard general case: if for each set of ghost points you may need several
>entries from one grid point and a different number of entries from another
>grid point VecScatterCreate() (called multiple times, one for each pattern)
>and VecScatterBegin/End() are intended for this purpose. However if you are
>working with a 2 dimension grid/array you want to do ghosting for you need
>to initially map your ghosting patterns from the 2d indexing to the 1d
>indexing of the VecScatterCreate() which is a bit painful. You can see the
>routine I mentioned before DMSetUp_DA_2D() but it would need to be
>heavily modified.
>2) The easy case: if, for example, you need just the first index from each
>point communicated as a ghost and then next the second and then next the
>third you can avoid all custom communication patterns and just create 2
>DMDA, one with a dof of 100 (or what ever it is for your case) and one with
>dof of 1 then use VecStrideGather to pull out the one component of the
>global vector (with the dof of 100) into a Vec obtained from
>DMCreateGlobalVector() from the dof of 1 DMDA then use the
>DMGlobalToLocalBegin/End on the 1 dof DMDA and now you have your single
>ghost point at each point vector that you want.
>   Barry
>On Feb 21, 2014, at 1:12 PM, Fischer, Greg A. <fischega at westinghouse.com>
>wrote:
>> Barry,
>> Thanks!  I have another question. The user manual says:
>>                 PETSc currently provides no container for multiple arrays sharing
>the same distributed array communication; note, however, that the dof
>parameter handles many cases of interest.
>> In my application, each space location will have on the order of hundreds of
>values associated with it (which I believe translates to dof=O(100) - I don't
>see the "degrees of freedom" explicitly defined anywhere). However, when
>communicating ghost values, not all of those degrees of freedom should be
>exchanged at once. I need to be able to exchange one at a time.
>> It sounds like what I may want to do is use VecCreateGhost(), which would
>allow me to define exactly where the ghost points are, and then duplicate
>that vector using VecDuplicateVecs() for each DOF. I can then scatter the
>vectors individually as the need arises. Does that sound reasonable?
>> Greg
>> >Sent: Friday, February 21, 2014 12:21 PM
>> >On Feb 21, 2014, at 11:02 AM, Fischer, Greg A.
>> >wrote:
>> >> Hello,
>> >> I'm interested in using PETSc to manage distributed arrays. Based
>> >> on my
>> >reading about the DMDA objects, I see that ghost points can be
>> >communicated in box-type stencils or star-type stencils.
>> >> For my application, assume that I have a 2D DMDA object with
>> >> star-type
>> >stencils. For a typical local calculation, I only need to access
>> >ghost values from two of the four directions at a time. For example,
>> >I'd like access to ghost values in the South and East directions, but
>> >not in the North or West directions. Communicating North and West
>> >data would seem to be wasting bandwidth. Is there any way to accomplish
>this?
>> >   Greg,
>> >    There is not anything built in. Here is what I suggest:
>> >1)  write your application code not worrying about the fact that the
>> >DMGlobalToLocalBegin/End() is moving values you don't need.
>> >2) when your code is running correctly for your problem and giving
>> >useful results if the communication times are impacting how long it
>> >takes to run you can provide a custom communication pattern. It would
>> >involve little additional coding essentially taking DMSetUp_DA_2D()
>> >which creates the list of ghost points and removing the  unneeded
>> >ghost points.  But it would be premature to do this optimization
>> >until you have a full working application code.
>> >   Barry
>> >> Thanks,
>> >> Greg
