[petsc-users] Adaptive implicit method with PETSC
    Matthew Knepley
    knepley at gmail.com
    Wed Dec 17 16:08:46 CST 2014
On Wed, Dec 17, 2014 at 3:59 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Hi,
> I am trying to find a best way to implement adaptive implicit method
> (AIM) using PETSc for the linear solver.
> I am solving conservation equations so if I have a N cells problem then I
> will end of solving a N*M by N*M linear system matrix for each cell has M
> equations (or variables) when I solve them fully implicitly.  For such
> system I can use blocked matrix (BAIJ)
> In case each cell has its implicitness level varing from 1 to M so each
> sub block will have different size range from 1 by to M by M so BAIJ will
> be very inefficient in both storage and computations I supposed.
> So I am actually thinking if I should reconstruct matrix and using point
> matrix (AIJ) when implicitness changes but will this also too inefficient
> for constructing a new matrix?
This should be alright with AIJ since we have an "inodes" mechanism which
looks like adaptive block size.
    Matt
> So what is the best way for me to implement AIM?
> Kan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141217/d406756b/attachment.html>
