[petsc-users] PETSC-3.5.0 with SuperLU and Hypre
Fri Aug 29 11:46:26 CDT 2014
src/ksp/pc/impls/hypre/hypre.c is listed in files.
However make.log is empty.
Can you do 'make allclean' again' and resend
make.log and arch-linux2-c-debug/conf/files
And what do you have for:
make --version
Satish
On Fri, 29 Aug 2014, Kai Song wrote:
> Hi Satish and Jed,
> I did a "make allclean", and reconfigured with "-with-shared-libraries=0".
> I am still seeing the same error.
> Then I deleted arch-linux2-c-debug/conf/files, and remake. The "make test"
> failed again.
> I have attached the new configure.log, make.log, and
> rch-linux2-c-debug/conf/files in this email.
> Thanks,
> Kai
> On Fri, Aug 29, 2014 at 9:25 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Matthew Knepley <knepley at gmail.com> writes:
> > > On Fri, Aug 29, 2014 at 10:59 AM, Kai Song <ksong at lbl.gov> wrote:
> > >> Hi Matt,
> > >> Thanks for the quick response. Both logs are included in the attachment.
> > >> Let me know if more log files are needed.
> > > Jed, why does this not enter src/mat/impls/aij/seq/superlu?
> > Kai, can you delete
> > and re-run make (it should regenerate this file).  If superlu is not
> > compiled, please send the contents of that file.
