[petsc-users] Fwd: PETSC-3.5.0 with SuperLU and Hypre
Kai Song ksong at lbl.gov
Fri Aug 29 11:40:43 CDT 2014
---------- Forwarded message ----------
Date: Fri, Aug 29, 2014 at 9:32 AM
Subject: Re: [petsc-users] PETSC-3.5.0 with SuperLU and Hypre
To: Jed Brown <jedbrown at mcs.anl.gov>
Cc: Matthew Knepley <knepley at gmail.com>, petsc-users <
petsc-users at mcs.anl.gov>, Evan Um <evanum at gmail.com>, Evan Um <ESUm at lbl.gov>
Hi Satish and Jed,
I did a "make allclean", and reconfigured with "-with-shared-libraries=0".
I am still seeing the same error.
Then I deleted arch-linux2-c-debug/conf/files, and remake. The "make test"
failed again.
I have attached the new configure.log, make.log, and
rch-linux2-c-debug/conf/files in this email.
Kai
On Fri, Aug 29, 2014 at 9:25 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, Aug 29, 2014 at 10:59 AM, Kai Song <ksong at lbl.gov> wrote:
> >> Hi Matt,
> >> Thanks for the quick response. Both logs are included in the attachment.
> >> Let me know if more log files are needed.
> > Jed, why does this not enter src/mat/impls/aij/seq/superlu?
> Kai, can you delete
> and re-run make (it should regenerate this file).  If superlu is not
> compiled, please send the contents of that file.
Kai Song
<ksong at lbl.gov> 1.510.495.2180
1 Cyclotron Rd. Berkeley, CA94720, MS-50B 3209
High Performance Computing Services (HPCS)
Lawrence Berkeley National Laboratory - http://scs.lbl.gov
Kai Song
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/4f5c63a5/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/4f5c63a5/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/4f5c63a5/attachment-0001.obj>
