[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Dominic Meiser dmeiser at txcorp.com
Thu Aug 28 09:38:12 CDT 2014
Can you try configuring with
--with-thrust-dir=/usr/local/cuda-6.0/include
I.e. omit the 'thrust' at the end of the path. Probably you'll need the
same fix with cusp:
--with-cusp-dir=/usr/local/cuda-6.0/include
Cheers,
Dominic
On 08/28/2014 08:13 AM, Christophe Ortiz wrote:
> Hi all,
> I have implemented a problem of coupled diffusion equations in 1D
> using PETSc. I was able to configure PETSC with and without MPI. The
> code runs well in both cases.
> Now I would like to test CUDA but I am unable to configure it. I get
> an error message related to thrust directory.
> The options I use to configure are the following:
> --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc
> --with-clanguage=cxx --with-fc=ifort --with-cuda=1
> --with-cuda-dir=/usr/local/cuda-6.0 --with-cuda-arch=sm_35
> --with-cudac=/usr/local/cuda/bin/nvcc --with-thrust=1
> --with-thrust-dir=/usr/local/cuda-6.0/include/thrust --with-cusp=1
> --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
> --download-txpetscgpu=1 --with-debugging=1 --with-scalar-type=real
> --with-precision=double --download-f-blas-lapack
> The error message I get is:
>              Configuring PETSc to compile on your system
> TESTING: checkInclude from
> config.headers(config/BuildSystem/config/headers.py:86)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> --with-thrust-dir=/usr/local/cuda-6.0/include/thrust did not work
> Did I miss something ?
> My GPU is a GeForce Titan Black and I am using CUDA 6.0.
> Many thanks in advance for your help.
> Christophe
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
