[petsc-users] Unable to configure PETSc with CUDA: Problem with thrust directory
Christophe Ortiz christophe.ortiz at ciemat.es
Thu Aug 28 09:19:49 CDT 2014
I forgot to mention that I am using PETSc 3.4.1.
On Thu, Aug 28, 2014 at 4:13 PM, Christophe Ortiz <
christophe.ortiz at ciemat.es> wrote:
> Hi all,
> I have implemented a problem of coupled diffusion equations in 1D using
> PETSc. I was able to configure PETSC with and without MPI. The code runs
> well in both cases.
> Now I would like to test CUDA but I am unable to configure it. I get an
> error message related to thrust directory.
> The options I use to configure are the following:
> --with-x=1 --with-mpi=0 --with-cc=icc --with-cxx=icpc --with-clanguage=cxx
> --with-fc=ifort --with-cuda=1 --with-cuda-dir=/usr/local/cuda-6.0
> --with-cuda-arch=sm_35 --with-cudac=/usr/local/cuda/bin/nvcc
> --with-thrust=1 --with-thrust-dir=/usr/local/cuda-6.0/include/thrust
> --with-cusp=1 --with-cusp-dir=/usr/local/cuda-6.0/include/cusp
> --download-txpetscgpu=1 --with-debugging=1 --with-scalar-type=real
> --with-precision=double --download-f-blas-lapack
> The error message I get is:
>              Configuring PETSc to compile on your system
> TESTING: checkInclude from
> config.headers(config/BuildSystem/config/headers.py:86)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> --with-thrust-dir=/usr/local/cuda-6.0/include/thrust did not work
> Did I miss something ?
> My GPU is a GeForce Titan Black and I am using CUDA 6.0.
> Many thanks in advance for your help.
> Christophe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140828/ca293019/attachment.html>
