[petsc-users] Out-of-memory, reading ASCII files using single processor
Jed Brown jed at jedbrown.org
Mon Aug 18 10:12:57 CDT 2014
jifeng zhao <jifengzhao2015 at u.northwestern.edu> writes:
> Hi Jed,
> Actually the out-of-memory happened when converting ASCII files to petsc
> format using a serial PETSc program.
> It seems a single processor doesn't have enough memory to preallocate
> enough space to store the matrices. Is there any way around it...?
How did you create the matrices in the first place?  What ASCII format
are you using?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140818/bcb6a775/attachment.pgp>
