[petsc-users] MatGetSubMatrix for a Nested matrix
Khai Hong Pham khaipham at utexas.edu
Mon Aug 11 16:22:20 CDT 2014
Thank you for your information, Matt. I'm using both nested matrix and
nested vector. Is the nested vector good to use ?
Khai.
On Mon, Aug 11, 2014 at 4:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 11, 2014 at 3:53 PM, Khai Hong Pham <khaipham at utexas.edu>
> wrote:
>> Matt,
>> I've the following error as I tried to get the sub block matrix. I check
>> the isrow and iscol that are passed to MatGetSubMatrix and they look ok
>> to me. The line 110 of  ISStrideGetInfo() calls
>> to PetscValidHeaderSpecific.
> You have something corrupt in the MatNest. Quit using MatNest. This is
> just an optimization that should
> only be turned on by -mat_type nest. It is not a top level interface. This
> causes so many problems that we
> should remove it from the documentation.
>   Thanks,
>       Matt
>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>> [0]PETSC ERROR: Null Object: Parameter # 1
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
>> [0]PETSC ERROR: [1]PETSC ERROR: ./PFFEM2DSolver on a arch-linux2-c-debug
>> named khp by khp Mon Aug 11 15:26:47 2014
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
>> --download-metis --download-parmetis
>> [1]PETSC ERROR: Null Object: Parameter # 1
>> [1]PETSC ERROR: [0]PETSC ERROR: #1 ISStrideGetInfo() line 110 in
>> /home/khp/bin/petsc-3.5.1/src/vec/is/is/impls/stride/stride.c
>> See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> [1]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
>> [1]PETSC ERROR: ./PFFEM2DSolver on a arch-linux2-c-debug named khp by khp
>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> [1]PETSC ERROR: #1 ISStrideGetInfo() line 110 in
>> [0]PETSC ERROR: #2 MatNestFindSubMat() line 357 in
>> /home/khp/bin/petsc-3.5.1/src/mat/impls/nest/matnest.c
>> [0]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 411 in
>> [0]PETSC ERROR: #4 MatGetLocalSubMatrix() line 9224 in
>> /home/khp/bin/petsc-3.5.1/src/mat/interface/matrix.c
>> [1]PETSC ERROR: #2 MatNestFindSubMat() line 357 in
>> [0]PETSC ERROR: #5 jacobian_comp() line 49 in src/assembly.cpp
>> [1]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 411 in
>> [0]PETSC ERROR: [1]PETSC ERROR: #6 TaoComputeJacobian() line 153 in
>> /home/khp/bin/petsc-3.5.1/src/tao/interface/taosolver_hj.c
>> [0]PETSC ERROR: [1]PETSC ERROR: #7 Tao_SSLS_FunctionGradient() line 63 in
>> /home/khp/bin/petsc-3.5.1/src/tao/complementarity/impls/ssls/ssls.c
>> [0]PETSC ERROR: #8 TaoLineSearchComputeObjectiveAndGradient() line 941 in
>> /home/khp/bin/petsc-3.5.1/src/tao/linesearch/interface/taolinesearch.c
>> [0]PETSC ERROR: #9 TaoSolve_SSILS() line 65 in
>> /home/khp/bin/petsc-3.5.1/src/tao/complementarity/impls/ssls/ssils.c
>> [0]PETSC ERROR: #10 TaoSolve() line 188 in
>> /home/khp/bin/petsc-3.5.1/src/tao/interface/taosolver.c
>> [1]PETSC ERROR: #8 TaoLineSearchComputeObjectiveAndGradient() line 941 in
>> [0]PETSC ERROR: #11 main() line 286 in src/main.cpp
>> [1]PETSC ERROR: #9 TaoSolve_SSILS() line 65 in
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> [1]PETSC ERROR: #10 TaoSolve() line 188 in
>> [1]PETSC ERROR: #11 main() line 286 in src/main.cpp
>> [1]PETSC ERROR: ----------------End of Error Message -------send entire
>> On Mon, Aug 11, 2014 at 12:34 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Aug 11, 2014 at 12:05 PM, Khai Hong Pham <khaipham at utexas.edu>
>>> wrote:
>>>> Hello Petsc-Users,
>>>> In the MatGetSubMatrix, if the matrix mat is a nested matrix, for
>>>> example [ A00 A01 | A10 A11], and I'd like to get submat  A10. Then the
>>>> isrow and iscol will be the index of the subblock matrix which is (1,0) or
>>>> it must be the index of all rows, columns of the submat in the mat (like in
>>>> MatGetSubMatrix). Please help me to clarify this.
>>> It is the later (the list of rows/cols)
>>>   Thsnks,
>>>     Matt
>>>> Thanks
>>>> Khai
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140811/32d20ff7/attachment-0001.html>
