[petsc-users] MatGetSubMatrix for a Nested matrix
Mon Aug 11 16:16:38 CDT 2014
On Mon, Aug 11, 2014 at 3:53 PM, Khai Hong Pham <khaipham at utexas.edu> wrote:
> Matt,
> I've the following error as I tried to get the sub block matrix. I check
> the isrow and iscol that are passed to MatGetSubMatrix and they look ok
> to me. The line 110 of  ISStrideGetInfo() calls
> to PetscValidHeaderSpecific.
You have something corrupt in the MatNest. Quit using MatNest. This is just
an optimization that should
only be turned on by -mat_type nest. It is not a top level interface. This
causes so many problems that we
should remove it from the documentation.
      Matt
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Object: Parameter # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
> [0]PETSC ERROR: [1]PETSC ERROR: ./PFFEM2DSolver on a arch-linux2-c-debug
> named khp by khp Mon Aug 11 15:26:47 2014
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
> --download-metis --download-parmetis
> [1]PETSC ERROR: Null Object: Parameter # 1
> [1]PETSC ERROR: [0]PETSC ERROR: #1 ISStrideGetInfo() line 110 in
> /home/khp/bin/petsc-3.5.1/src/vec/is/is/impls/stride/stride.c
> See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [1]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
> [1]PETSC ERROR: ./PFFEM2DSolver on a arch-linux2-c-debug named khp by khp
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> [1]PETSC ERROR: #1 ISStrideGetInfo() line 110 in
> [0]PETSC ERROR: #2 MatNestFindSubMat() line 357 in
> /home/khp/bin/petsc-3.5.1/src/mat/impls/nest/matnest.c
> [0]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 411 in
> [0]PETSC ERROR: #4 MatGetLocalSubMatrix() line 9224 in
> /home/khp/bin/petsc-3.5.1/src/mat/interface/matrix.c
> [1]PETSC ERROR: #2 MatNestFindSubMat() line 357 in
> [0]PETSC ERROR: #5 jacobian_comp() line 49 in src/assembly.cpp
> [1]PETSC ERROR: #3 MatGetLocalSubMatrix_Nest() line 411 in
> [0]PETSC ERROR: [1]PETSC ERROR: #6 TaoComputeJacobian() line 153 in
> /home/khp/bin/petsc-3.5.1/src/tao/interface/taosolver_hj.c
> [0]PETSC ERROR: [1]PETSC ERROR: #7 Tao_SSLS_FunctionGradient() line 63 in
> /home/khp/bin/petsc-3.5.1/src/tao/complementarity/impls/ssls/ssls.c
> [0]PETSC ERROR: #8 TaoLineSearchComputeObjectiveAndGradient() line 941 in
> /home/khp/bin/petsc-3.5.1/src/tao/linesearch/interface/taolinesearch.c
> [0]PETSC ERROR: #9 TaoSolve_SSILS() line 65 in
> /home/khp/bin/petsc-3.5.1/src/tao/complementarity/impls/ssls/ssils.c
> [0]PETSC ERROR: #10 TaoSolve() line 188 in
> /home/khp/bin/petsc-3.5.1/src/tao/interface/taosolver.c
> [1]PETSC ERROR: #8 TaoLineSearchComputeObjectiveAndGradient() line 941 in
> [0]PETSC ERROR: #11 main() line 286 in src/main.cpp
> [1]PETSC ERROR: #9 TaoSolve_SSILS() line 65 in
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> [1]PETSC ERROR: #10 TaoSolve() line 188 in
> [1]PETSC ERROR: #11 main() line 286 in src/main.cpp
> [1]PETSC ERROR: ----------------End of Error Message -------send entire
> On Mon, Aug 11, 2014 at 12:34 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Aug 11, 2014 at 12:05 PM, Khai Hong Pham <khaipham at utexas.edu>
>> wrote:
>>> Hello Petsc-Users,
>>> In the MatGetSubMatrix, if the matrix mat is a nested matrix, for
>>> example [ A00 A01 | A10 A11], and I'd like to get submat  A10. Then the
>>> isrow and iscol will be the index of the subblock matrix which is (1,0) or
>>> it must be the index of all rows, columns of the submat in the mat (like in
>>> MatGetSubMatrix). Please help me to clarify this.
>> It is the later (the list of rows/cols)
>>   Thsnks,
>>     Matt
>>> Thanks
>>> Khai
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140811/2755870a/attachment.html>
