[petsc-users] KSPSetUp hanging up with HYPRE preconditioner
Fri Aug 8 13:26:20 CDT 2014
On Fri, Aug 8, 2014 at 1:19 PM, Ghosh, Swarnava <sghosh2012 at gatech.edu>
wrote:
> Hello,
>     I am using petsc 3.4.1 interfaced with hypre 2.9.0b
>     I am using the following lines of code to solve a Poisson equation
> using KSPGMRES with HYPRE preconditioner.
>     pOfdft->laplaceOpr is a sparse matrix in MATMPIBAIJ format.
>   KSPCreate(PETSC_COMM_WORLD,&pOfdft->ksp);
>   KSPSetType(pOfdft->ksp,KSPGMRES);
> KSPSetTolerances(pOfdft->ksp,KSPTOL,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
> KSPSetOperators(pOfdft->ksp,pOfdft->laplaceOpr,pOfdft->laplaceOpr,SAME_NONZERO_PATTERN);
>   KSPGetPC(pOfdft->ksp,&pOfdft->pc);
>   PCSetType(pOfdft->pc,PCHYPRE);
>   PCHYPRESetType(pOfdft->pc,"boomeramg");
>   KSPSetFromOptions(pOfdft->ksp);
>   KSPSetUp(pOfdft->ksp);
>     The code runs fine when the size of matrix is small (4096 X 4096).
>     BUT the code remains stuck in KSPSetUp function when the size of
> matrix is bigger (262144 x262144) on 64 cores 120 gb ram.
>    Could you please let me know the probable reason the why the code is
> hanging in KSPSetUp.
>    If possible could you please share some C examples where you use a
> HYPRE preconditioner for solving a large system
To me it sounds like Hypre is not "hanging up", but "taking a long time".
Hypre can have a large setup time compared to some
other types of MG, for example agglomeration. You could compare using
-pc_type gamg.
     Matt
> Thanks,
> Swarnava
> Swarnava Ghosh
> PhD Candidate,
> Structural Engineering, Mechanics and Materials
> School of Civil and Environmental Engineering
> Georgia Institute of Technology
> Atlanta, GA 30332
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140808/c8845fec/attachment.html>
