[petsc-users] Some possible bugs with PETSC_VIEWER_BINARY_?
Sun, Hui hus003 at ucsd.edu
Sat Aug 2 12:33:55 CDT 2014
I have just tested the PETSC_VIEW_BINARY_ on other test codes, they all work pretty well with multiple processors. Maybe I shouldn't be using ex70.c as a template any more.
Best,
Hui
Sent: Saturday, August 02, 2014 9:56 AM
To: Matthew Knepley
Cc: Jed Brown; petsc-users at mcs.anl.gov
Subject: RE: [petsc-users] Some possible bugs with PETSC_VIEWER_BINARY_?
That's true. But I'm using finite difference.
Best,
Hui
Sent: Saturday, August 02, 2014 9:51 AM
To: Sun, Hui
Subject: Re: [petsc-users] Some possible bugs with PETSC_VIEWER_BINARY_?
On Sat, Aug 2, 2014 at 11:17 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
I do have my code set up based on ex70. The reason I do this is that I need to use fieldsplit and schur complement. I can't find other examples doing that, except ex55 and ex70, however I have a hard time get ex55 running.
I don't understand what you said about "This example uses a simple decomposition, not what you use above". What do you mean by "simple decomposition"?
I use FieldSplit and schur on SNES ex62.
   Matt
From: Jed Brown [jed at jedbrown.org<mailto:jed at jedbrown.org>]
Sent: Friday, August 01, 2014 11:15 PM
To: Sun, Hui; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
"Sun, Hui" <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> writes:
> Here you can see I have 4 processors running at the same time. I read in the output from MATLAB using the
> command [A,B,C,D,x,b,y] = PetscBinaryRead('binaryoutput').
> And I visualize the variable y by the commands:
> mesh(reshape(y(20001:30000),100,100))
> mesh(reshape(y(10001:20000),100,100))
> mesh(reshape(y(1:10000),100,100))
> The output plots are different from what I get if I use 1 processor.
This example uses a simple decomposition, not what you use above.
Note that this example was contributed and we do not endorse it as
recommended practice.  If your code is already set up very much like
this, it may be worth looking at, but don't write new code in this way
because it is algorithmically constraining.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140802/cd89ae16/attachment.html>
