[petsc-users] parmetis error when using more than one block per processor in asm
Jed Brown jed at jedbrown.org
Fri Aug 1 16:59:32 CDT 2014
Can you turn on debugging (it does more input validation) and attempt to
reproduce with a PETSc example or a short test case that you can share
with us?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140801/b3344018/attachment.pgp>
