[petsc-users] parmetis error when using more than one block per processor in asm
James MBewu james.mbewu at cs.ox.ac.uk
Fri Aug 1 04:50:26 CDT 2014
Hi all,
I'm solving a Navier Stokes system. I am having a problem whereby when I
try to use asm as a preconditioner and make the number of blocks more than
one per mpi proc I get an error from within parmetis (when I attempt the
same with bjacobi I don't get an error). Also when I run with exactly one
block per processor there are no issues. Any tips? Error message below.
Cheers,
James
PARMETIS ERROR: The sum of tpwgts for constraint #0 is not 1.0
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 76.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Error in external library!
[1]PETSC ERROR: ParMETIS general error in ParMETIS_V3_PartKway!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR:
/home/james/libmesh-0.9.3/examples/fem_system/fem_system_ex1/.libs/lt-example-opt
on a linux-opt named james-SATELLITE-C855-18D by james Fri Aug  1 10:45:36
[1]PETSC ERROR: Libraries linked from /home/james/petsc-3.4.2/linux-opt/lib
[1]PETSC ERROR: Configure run at Wed Jul  9 14:22:40 2014
[1]PETSC ERROR: Configure options ./configure --with-mpi=1 --with-x=0
--download-scalapack=1 --download-metis=1 --download-parmetis=1
--download-mumps=1 --download-hypre=1 --download-f-blas-lapack=1
--download-ml=1 --download-superlu_dist=1 --download-superlu=1
--download-umfpack=1 --download-ptscotch=1 --download-gamg=1
--download-pastix=1 --with-debugging=0
[1]PETSC ERROR:
[1]PETSC ERROR: MatPartitioningApply_Parmetis() line 104 in
/home/james/petsc-3.4.2/src/mat/partition/impls/pmetis/pmetis.c
[0]PETSC ERROR: Error in external library!
[0]PETSC ERROR: ParMETIS general error in ParMETIS_V3_PartKway!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR: Libraries linked from /home/james/petsc-3.4.2/linux-opt/lib
[0]PETSC ERROR: Configure run at Wed Jul  9 14:22:40 2014
[0]PETSC ERROR: Configure options ./configure --with-mpi=1 --with-x=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatPartitioningApply_Parmetis() line 104 in
[0]PETSC ERROR: MatPartitioningApply() line 225 in
/home/james/petsc-3.4.2/src/mat/partition/partition.c
[0]PETSC ERROR: PCASMCreateSubdomains() line 1210 in
/home/james/petsc-3.4.2/src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: PCSetUp_ASM() line 232 in
[0]PETSC ERROR: PCSetUp() line 890 in
/home/james/petsc-3.4.2/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 278 in
/home/james/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 399 in
[0]PETSC ERROR: solve() line 763 in
"unknowndirectory/"src/solvers/petsc_linear_solver.C
[1]PETSC ERROR: MatPartitioningApply() line 225 in
[1]PETSC ERROR: PCASMCreateSubdomains() line 1210 in
[1]PETSC ERROR: PCSetUp_ASM() line 232 in
[1]PETSC ERROR: PCSetUp() line 890 in
[1]PETSC ERROR: KSPSetUp() line 278 in
[1]PETSC ERROR: KSPSolve() line 399 in
[1]PETSC ERROR: solve() line 763 in
mpirun has exited due to process rank 1 with PID 5356 on
node james-SATELLITE-C855-18D exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported hPARMETIS ERROR: The sum
with errorcode 76.
[1]PETSC ERROR:
[1]PETSC ERROR:
[1]PETSC ERROR:
[1]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR:
terminated by signals sent by mpirun (as reported here).
[james-SATELLITE-C855-18D:05354] 1 more process has sent help message
help-mpi-api.txt / mpi-abort
[james-SATELLITE-C855-18D:05354] Set MCA parameter
"orte_base_help_aggregate" to 0 to see all help / error messages
ere).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140801/5cfc2e7e/attachment-0001.html>
