[petsc-users] Assembling a finite element matrix in parallel
Sun Apr 27 08:35:41 CDT 2014
On Sun, Apr 27, 2014 at 7:47 AM, Justin Dong <jsd1 at rice.edu> wrote:
> I think I've got the right idea on how to divide up the for loop:
>     MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
>     MPI_Comm_rank(MPI_COMM_WORLD,&myid);
>     mystart = (nelements / numprocs) * myid;
>     if (nelements % numprocs > myid)
>     mystart += myid;
>     myend = mystart + (nelements / numprocs) + 1;
>     else
>     mystart += nelements % numprocs;
>     myend = mystart + (nelements / numprocs);
We have a function that does exactly this:
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscSplitOwnership.html
> But then, do I do this?
Yes.
> for (k = mystart+1; k < myend; ++k)
>     get_index(k,ie,je); /* ie and je are arrays that indicate where to
> place A_local */
>     compute_local_matrix(A_local,...);
>     MatSetValues(A_global, nlocal, ie, nlocal, je, A_local, ADD_VALUES);
> The indices are global indices and I'm doing
> MatCreateSeqAIJ(PETSC_COMM_WORLD, nglobal, nglobal, 3*nlocal,
>     PETSC_NULL, &A_global);
This should be MatCreateMPIAIJ() for parallel execution.
   Matt
to create the matrix. Running the program seems to give me multiple errors,
> but mainly
> [3]PETSC ERROR: Object is in wrong state!
> [3]PETSC ERROR: Mat object's type is not set: Argument # 1!
> On Sun, Apr 27, 2014 at 6:54 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Apr 27, 2014 at 6:25 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>> Hi Matt,
>>> For option 1), that would be using MPI and not any special functions in
>>> PETSc? I ask since I've never done parallel programming before. I tried
>>> using OpenMP to parallelize that for loop but it resulted in some errors
>>> and I didn't investigate further, but I'm assuming it's because each
>>> process wasn't communicating properly with the others during MatSetValues?
>> Yes, using MPI, so each process owns a set of elements that it loops
>> over. The Mat object manages the global
>> values as long as you use global indices for the (row, column). There are
>> of course many refinements for this,
>> but I think the thing to do is get something working fast, and then
>> optimize it.
>>   Thanks,
>>      Matt
>>> Sincerely,
>>> Justin
>>> On Sun, Apr 27, 2014 at 5:57 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Sun, Apr 27, 2014 at 4:14 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>>> Hi all,
>>>>> I'm currently coding a finite element problem in PETSc. I'm computing
>>>>> all of the matrices by myself and would prefer to do it that way. I want to
>>>>> parallelize the assembly of the global matrices. This is a simplified
>>>>> version of the assembly routine (pseudocode):
>>>>> for (k = 0; k < nelements; ++k)
>>>>> place A_local */
>>>>> ADD_VALUES);
>>>>> This is for DG finite elements and I know the matrix easily be
>>>>> assembled in parallel. Even on my laptop, this would allow me to
>>>>> significantly speed up my code. The only problem is, I'm not sure how to do
>>>>> this in PETSc. I'd assume I need to use MatCreateMPIAIJ instead of
>>>>> MatCreateSeqAIJ, but wasn't able to find any using tutorials on how I might
>>>>> do this.
>>>> 1) If you just split this loop across processes, it would work
>>>> immediately. However, that can be non-optimal in terms
>>>>      of communication.
>>>> 2) PETSc matrices are distributed by contiguous blocks of rows (see
>>>> manual section on matrices), so you would like
>>>>     those row blocks to correspond roughly to your element blocks.
>>>> 3) You will also have to preallocate, but that should be the same as
>>>> you do now for the sequential case, except you
>>>>      check whether a column is inside the diagonal block.
>>>>   Thanks,
>>>>       Matt
>>>>> Sincerely,
>>>>> Justin
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140427/e9dc07d1/attachment-0001.html>
