[petsc-users] Assembling a finite element matrix in parallel
Justin Dong jsd1 at rice.edu
Sun Apr 27 07:47:34 CDT 2014
I think I've got the right idea on how to divide up the for loop:
    MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
    MPI_Comm_rank(MPI_COMM_WORLD,&myid);
    mystart = (nelements / numprocs) * myid;
    if (nelements % numprocs > myid)
    mystart += myid;
    myend = mystart + (nelements / numprocs) + 1;
    else
    mystart += nelements % numprocs;
    myend = mystart + (nelements / numprocs);
But then, do I do this?
for (k = mystart+1; k < myend; ++k)
    get_index(k,ie,je); /* ie and je are arrays that indicate where to
place A_local */
    compute_local_matrix(A_local,...);
    MatSetValues(A_global, nlocal, ie, nlocal, je, A_local, ADD_VALUES);
The indices are global indices and I'm doing
MatCreateSeqAIJ(PETSC_COMM_WORLD, nglobal, nglobal, 3*nlocal,
    PETSC_NULL, &A_global);
to create the matrix. Running the program seems to give me multiple errors,
but mainly
[3]PETSC ERROR: Object is in wrong state!
[3]PETSC ERROR: Mat object's type is not set: Argument # 1!
On Sun, Apr 27, 2014 at 6:54 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Apr 27, 2014 at 6:25 AM, Justin Dong <jsd1 at rice.edu> wrote:
>> Hi Matt,
>> For option 1), that would be using MPI and not any special functions in
>> PETSc? I ask since I've never done parallel programming before. I tried
>> using OpenMP to parallelize that for loop but it resulted in some errors
>> and I didn't investigate further, but I'm assuming it's because each
>> process wasn't communicating properly with the others during MatSetValues?
> Yes, using MPI, so each process owns a set of elements that it loops over.
> The Mat object manages the global
> values as long as you use global indices for the (row, column). There are
> of course many refinements for this,
> but I think the thing to do is get something working fast, and then
> optimize it.
>   Thanks,
>      Matt
>> Sincerely,
>> Justin
>> On Sun, Apr 27, 2014 at 5:57 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sun, Apr 27, 2014 at 4:14 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>> Hi all,
>>>> I'm currently coding a finite element problem in PETSc. I'm computing
>>>> all of the matrices by myself and would prefer to do it that way. I want to
>>>> parallelize the assembly of the global matrices. This is a simplified
>>>> version of the assembly routine (pseudocode):
>>>> for (k = 0; k < nelements; ++k)
>>>> place A_local */
>>>> This is for DG finite elements and I know the matrix easily be
>>>> assembled in parallel. Even on my laptop, this would allow me to
>>>> significantly speed up my code. The only problem is, I'm not sure how to do
>>>> this in PETSc. I'd assume I need to use MatCreateMPIAIJ instead of
>>>> MatCreateSeqAIJ, but wasn't able to find any using tutorials on how I might
>>>> do this.
>>> 1) If you just split this loop across processes, it would work
>>> immediately. However, that can be non-optimal in terms
>>>      of communication.
>>> 2) PETSc matrices are distributed by contiguous blocks of rows (see
>>> manual section on matrices), so you would like
>>>     those row blocks to correspond roughly to your element blocks.
>>> 3) You will also have to preallocate, but that should be the same as you
>>> do now for the sequential case, except you
>>>      check whether a column is inside the diagonal block.
>>>   Thanks,
>>>       Matt
>>>> Sincerely,
>>>> Justin
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140427/a09dc6ed/attachment.html>
