[petsc-users] PETSc-gamg default setting
Fri Apr 25 11:31:38 CDT 2014
On Fri, Apr 25, 2014 at 11:26 AM, 藤井昭宏 <fujii at cc.kogakuin.ac.jp> wrote:
> Hello everybody,
> I’d like to compare a solver with PETSc-gamg for Poisson problems.
> I used PETSc version 3.4.3., and the following command line option.
>  -ksp_type “bcgs” -pc_type “gamg” -ksp_monitor -ksp_rtol 1.0E-7
> -log_summary -pc_mg_log
> Would you give me some information on the following questions?
> - Does this option correspond to BICGSTAB solver with smoothed aggregation
> algebraic multigrid method?
Yes
> - Are coarser level small distributed matrices re-distributed to reduce
> the parallelism, when the number of processes is very large?
Yes
> -  What kind of smoother will be used for this command line option?
Cheby(2)/Jacobi is the default in GAMG.
> -  pc_mg_log option shows the MG Apply stage. Does this stage time
> correspond to the solver time except for multi-level setup time?
>    Does it include the time for BICGSTAB?
Yes, and no.
     Matt
> Thanks in advance.
> Akihiro Fujii
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/7a3298d6/attachment.html>
