[petsc-users] PETSc-gamg default setting
藤井昭宏 fujii at cc.kogakuin.ac.jp
Fri Apr 25 11:26:27 CDT 2014
Hello everybody,
I’d like to compare a solver with PETSc-gamg for Poisson problems.
I used PETSc version 3.4.3., and the following command line option.
 -ksp_type “bcgs” -pc_type “gamg” -ksp_monitor -ksp_rtol 1.0E-7 -log_summary -pc_mg_log
Would you give me some information on the following questions?
- Does this option correspond to BICGSTAB solver with smoothed aggregation algebraic multigrid method?
- Are coarser level small distributed matrices re-distributed to reduce the parallelism, when the number of processes is very large?
-  What kind of smoother will be used for this command line option?
-  pc_mg_log option shows the MG Apply stage. Does this stage time correspond to the solver time except for multi-level setup time?
   Does it include the time for BICGSTAB?
Thanks in advance.
Akihiro Fujii
