[petsc-users] infinite loop with NEWTONTR?
Norihiro Watanabe norihiro.w at gmail.com
Fri Apr 25 08:53:02 CDT 2014
attached is the output written until I killed the program. Please grep the
file with "Time step: 7" to go to log messages where the problem happens.
Nori
On Fri, Apr 25, 2014 at 3:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Run with -info and send ALL the output. -info triggers the printing of
> all the messages with from the calls to PetscInfo() thus we’ll be able to
> see what is happening to the values. In theory it should always eventually
> get out but there code be either a bug in our code or an error in your
> function evaluation that prevents it from ever getting out.
>    Barry
> On Apr 25, 2014, at 7:59 AM, Norihiro Watanabe <norihiro.w at gmail.com>
> wrote:
> > I mean "it's keep running but not print anything". I guess the program
> is running in while(1) loop after linear solve in SNESSolve_NEWTONTR() in
> src/snes/impls/tr/tr.c. But I'm not sure if the breaking condition (if (rho
> > neP->sigma) break; )  can be always satisfied at the end.
> > On Fri, Apr 25, 2014 at 2:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Apr 25, 2014, at 7:31 AM, Norihiro Watanabe <norihiro.w at gmail.com>
> wrote:
> > > Hi,
> > > In my simulation, nonlinear solve with the trust regtion method got
> stagnent after linear solve (see output below).
> >    What do you mean, get stagnant? Does the code just hang, that is keep
> running but not print anything.
> > > Is it possible that the method goes to inifite loop?
> >    This is not suppose to be possible.
> > > Is there any parameter to avoid this situation?
> >   You need to determine what it is “hanging” on. Try running with
> -start_in_debugger and when it “hangs” hit control C and type where to
> determine where it is.
> >    Barry
> > >   0 SNES Function norm 1.828728087153e+03
> > >     0 KSP Residual norm 91.2735
> > >     Linear solve converged due to CONVERGED_ITS iterations 1
> > >     Linear solve converged due to CONVERGED_RTOL iterations 3
> > >     1 KSP Residual norm 3.42223
> > >   Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
> > > Thank you in advance,
> > > Nori
> > Norihiro Watanabe
Norihiro Watanabe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/d5c2df05/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/d5c2df05/attachment-0001.bin>
