[petsc-users] infinite loop with NEWTONTR?
Norihiro Watanabe norihiro.w at gmail.com
Fri Apr 25 07:59:48 CDT 2014
I mean "it's keep running but not print anything". I guess the program is
running in while(1) loop after linear solve in SNESSolve_NEWTONTR() in src/
snes/impls/tr/tr.c. But I'm not sure if the breaking condition (if (rho >
neP->sigma) break; )  can be always satisfied at the end.
On Fri, Apr 25, 2014 at 2:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Apr 25, 2014, at 7:31 AM, Norihiro Watanabe <norihiro.w at gmail.com>
> wrote:
> > Hi,
> > In my simulation, nonlinear solve with the trust regtion method got
> stagnent after linear solve (see output below).
>    What do you mean, get stagnant? Does the code just hang, that is keep
> running but not print anything.
> > Is it possible that the method goes to inifite loop?
>    This is not suppose to be possible.
> > Is there any parameter to avoid this situation?
>   You need to determine what it is “hanging” on. Try running with
> -start_in_debugger and when it “hangs” hit control C and type where to
> determine where it is.
>    Barry
> >   0 SNES Function norm 1.828728087153e+03
> >     0 KSP Residual norm 91.2735
> >     Linear solve converged due to CONVERGED_ITS iterations 1
> >     Linear solve converged due to CONVERGED_RTOL iterations 3
> >     1 KSP Residual norm 3.42223
> >   Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
> > Thank you in advance,
> > Nori
Norihiro Watanabe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140425/0eba09e5/attachment.html>
