[petsc-users] MATLAB and PetSc
Tue Apr 22 12:49:18 CDT 2014
  PETSc does have a MATLAB interface in bin/matlab/classes that provides most of PETSc’s functionality directly to Matlab. Unfortunately we do not have the resources to maintain it, so it is a bit broken. If you are familiar with MATLAB and interfacing with C then git it a try and we can provide a small amount of support to help you use it, but as I said we cannot make it perfect ourselves.
   Barry
On Apr 22, 2014, at 12:19 PM, Sudheer Kumar <sudheer3 at gmail.com> wrote:
> On Tue, Apr 22, 2014 at 9:41 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> How much Matlab code do you have that computes the Jacobian and functions and is it parallel?
> The MATLAB code that I am working with is of 1000s lines of code (reservoir simulator, http://www.sintef.no/Projectweb/MRST/). The 90% of the time taken by the code on benchmarks is for linear solvers. And that's the reason to look for PetSc to speedup the entire code.
> >> This is a great deal of work and probably not worth it.
> Ok, unfortunately here I guess I need to attempt to do that work. Do let me know your suggestions. Thanks.
> Regards
> Sudheer
