[petsc-users] Preconditioner and number of processors
Jed Brown jed at jedbrown.org
Thu Apr 17 15:12:09 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> Always use a direct solver for fidelity tests, like SuperLU or MUMPS.
Direct solvers are good when you don't care about how the solve is done.
You can use -pc_type redundant in parallel, for example.
If you are interested in the way the solver behaves, consider -pc_type jacobi.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140417/aedd9572/attachment.pgp>
