[petsc-users] Preconditioner and number of processors
Thu Apr 17 14:57:01 CDT 2014
On Thu, Apr 17, 2014 at 2:48 PM, Xiao, Jianjun (IKET)
<jianjun.xiao at kit.edu>wrote:
> Dear developers,
> I find the words below in PETSc FAQ.
> "Most commonly, you are using a preconditioner which behaves differently
> based upon the number of processors, such as Block-Jacobi which is the
> PETSc default."
> I am testing the fidelity of my code. I don't want to be disturbed by the
> different numbers of procs. I know Block-Jacobi may be fast. But currently
> I don't care the speed. I need a preconditioner which behaves exactly the
> same with various procs. Which preconditioner should I use?
Always use a direct solver for fidelity tests, like SuperLU or MUMPS.
   Matt
> Thank you.
> Best regards
> JJ
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140417/634ded31/attachment.html>
