[petsc-users] MatMPIBAIJSetPreallocationCSR i and j indices
Sun Sep 29 16:20:24 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>    Also there is no way to get this flag into MatCreateMPIBAIJWithArrays()
>> The user calls MatSetOption before making that call and changes it
>> afterward if they want.
>    Huh?  I can't do
>    MatSetOption(?, MAT_ROW_ORIENTED,something)
>    MatCreateMPIBAIJWithArrays(……, &mat);
>    because mat doesn't exist before the MatCreate… () call. Now
>    obviously they could call the several routines instead of
Exactly.
>    but then we still need to decide what format
>    MatCreateMPIBAIJWithArrays() should use since the user cannot
>    choose from several. I conclude the best thing to do is to just use
>    the default column oriented as the only possibility.
Agreed, but I would do that by calling
MatSetOption(A,MAT_ROW_ORIENTED,PETSC_FALSE) inside
MatCreateMPIBAIJWithArrays and restoring it afterward, so that
MatMPIBAIJSetPreallocationCSR does not change that option.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130929/94f526e5/attachment.pgp>
