[petsc-users] Writing VTK output for vectors derived from DM Global vector
Fri Sep 27 12:14:30 CDT 2013
On Fri, Sep 27, 2013 at 10:12 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
> Hi,
> Does the vtk output write complex vectors? I wrote an example
> to test the usage but only the real part of the vector is written
> to the file. Is complex output supported?
I had never considered that since I did not know how VTK would plot it.
Does VTK support it?
If so, I can change the code to output what you want.
     Matt
> Thanks.
> Garnet
> On Tue, Sep 24, 2013 at 6:44 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
>> Hi Matt,
>> Yes. Thanks. I got it to work. The shell on emacs had not
>> updated $PETSC_DIR and was using 3.4.2.
>> Garnet
>> On Tue, Sep 24, 2013 at 6:26 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Sep 24, 2013 at 6:16 AM, Garnet Vaz <garnet.vaz at gmail.com>wrote:
>>>> Hi Matt,
>>>> I did pull yesterday. My configure.log file has
>>>>           Defined "VERSION_GIT" to
>>>> ""b4e904d1358c92c43842a940440f995d2117e40b""
>>>>           Defined "VERSION_DATE_GIT" to ""2013-09-23 12:36:08 +0100""
>>>> Is the change added after this?
>>> I see it here:
>>> https://bitbucket.org/petsc/petsc/src/33dd83b134909f5b4acb842818b1e0de2db2f4eb/include/petscdm.h?at=master#cl-35
>>> and it has been there since this commit in July:
>>> https://bitbucket.org/petsc/petsc/commits/38221697d93bc7c9a6149445938a5de22e85bc83
>>>       Matt
>>>> Garnet
>>>> On Tue, Sep 24, 2013 at 6:08 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Tue, Sep 24, 2013 at 5:54 AM, Garnet Vaz <garnet.vaz at gmail.com>wrote:
>>>>>> Hi,
>>>>>> Thanks Jed. I will set the field names before I write them.
>>>>>> I need to create a clone and then change the default section
>>>>>> to have dof to 1 before I write them. I am not able to use clone with
>>>>>> DMClone(originaldm,&newdm);
>>>>>> The error I get when compiling is
>>>>>> "'DMClone' was not declared in this scope".
>>>>>> I do have #include<petscdmplex.h> which includes the
>>>>>> petscdm.h header. Other than clone I am able to use the
>>>>>> other functions.
>>>>> Have you updated? I think I forgot the declaration initially.
>>>>>   Matt
>>>>>> Thanks.
>>>>>> Garnet
>>>>>> On Mon, Sep 23, 2013 at 3:30 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>>>>>> > Hi,
>>>>>>> > I would like to write out my solution to a VTK file where I use
>>>>>>> unstructured
>>>>>>> > grids in DMPlex.
>>>>>>> > The solution corresponds to  harmonic frequencies (~ 5-10
>>>>>>> distinct) which
>>>>>>> > are
>>>>>>> > currently saved into a Vec* object. These vectors were created by
>>>>>>> > duplicating the
>>>>>>> > global vector for the DM object. (I know that they correspond to
>>>>>>> the right
>>>>>>> > cell.)
>>>>>>> > Is it possible to have one file which would contain the mesh from
>>>>>>> the DM
>>>>>>> > object and all the Vec* objects?
>>>>>>> > Would I have to clone the original DM and use
>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerVTKAddField.html
>>>>>>> > to include all the vectors?
>>>>>>> This is a private function.
>>>>>>> > In the above function does
>>>>>>> > PetscViewerVTKWriteFunction
>>>>>>> > just need to be
>>>>>>> > myWriteFunc(vec,viewer)
>>>>>>> > VecView(vec,viewer)
>>>>>>> > if I do not need to make any changes to the vector?
>>>>>>> This should work, but you may want to use PetscObjectSetName() so
>>>>>>> that
>>>>>>> the names of the different fields are sensible.
>>>>>> Regards,
>>>>>> Garnet
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Regards,
>>>> Garnet
>>> experiments lead.
>>> -- Norbert Wiener
>> Regards,
>> Garnet
> Regards,
> Garnet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130927/8d645195/attachment.html>
