[petsc-users] Writing VTK output for vectors derived from DM Global vector
Garnet Vaz garnet.vaz at gmail.com
Fri Sep 27 12:12:26 CDT 2013
Does the vtk output write complex vectors? I wrote an example
to test the usage but only the real part of the vector is written
to the file. Is complex output supported?
Thanks.
Garnet
On Tue, Sep 24, 2013 at 6:44 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
> Hi Matt,
> Yes. Thanks. I got it to work. The shell on emacs had not
> updated $PETSC_DIR and was using 3.4.2.
> Garnet
> On Tue, Sep 24, 2013 at 6:26 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Sep 24, 2013 at 6:16 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
>>> Hi Matt,
>>> I did pull yesterday. My configure.log file has
>>>           Defined "VERSION_GIT" to
>>> ""b4e904d1358c92c43842a940440f995d2117e40b""
>>>           Defined "VERSION_DATE_GIT" to ""2013-09-23 12:36:08 +0100""
>>> Is the change added after this?
>> I see it here:
>> https://bitbucket.org/petsc/petsc/src/33dd83b134909f5b4acb842818b1e0de2db2f4eb/include/petscdm.h?at=master#cl-35
>> and it has been there since this commit in July:
>> https://bitbucket.org/petsc/petsc/commits/38221697d93bc7c9a6149445938a5de22e85bc83
>>       Matt
>>> Garnet
>>> On Tue, Sep 24, 2013 at 6:08 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Sep 24, 2013 at 5:54 AM, Garnet Vaz <garnet.vaz at gmail.com>wrote:
>>>>> Hi,
>>>>> Thanks Jed. I will set the field names before I write them.
>>>>> I need to create a clone and then change the default section
>>>>> to have dof to 1 before I write them. I am not able to use clone with
>>>>> DMClone(originaldm,&newdm);
>>>>> The error I get when compiling is
>>>>> "'DMClone' was not declared in this scope".
>>>>> I do have #include<petscdmplex.h> which includes the
>>>>> petscdm.h header. Other than clone I am able to use the
>>>>> other functions.
>>>> Have you updated? I think I forgot the declaration initially.
>>>>   Matt
>>>>> Thanks.
>>>>> Garnet
>>>>> On Mon, Sep 23, 2013 at 3:30 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>>>>> > Hi,
>>>>>> > I would like to write out my solution to a VTK file where I use
>>>>>> unstructured
>>>>>> > grids in DMPlex.
>>>>>> > The solution corresponds to  harmonic frequencies (~ 5-10 distinct)
>>>>>> which
>>>>>> > are
>>>>>> > currently saved into a Vec* object. These vectors were created by
>>>>>> > duplicating the
>>>>>> > global vector for the DM object. (I know that they correspond to
>>>>>> the right
>>>>>> > cell.)
>>>>>> > Is it possible to have one file which would contain the mesh from
>>>>>> the DM
>>>>>> > object and all the Vec* objects?
>>>>>> > Would I have to clone the original DM and use
>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerVTKAddField.html
>>>>>> > to include all the vectors?
>>>>>> This is a private function.
>>>>>> > In the above function does
>>>>>> > PetscViewerVTKWriteFunction
>>>>>> > just need to be
>>>>>> > myWriteFunc(vec,viewer)
>>>>>> > VecView(vec,viewer)
>>>>>> > if I do not need to make any changes to the vector?
>>>>>> This should work, but you may want to use PetscObjectSetName() so that
>>>>>> the names of the different fields are sensible.
>>>>> Regards,
>>>>> Garnet
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Regards,
>>> Garnet
>> experiments lead.
>> -- Norbert Wiener
> Regards,
> Garnet
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130927/edaaed5e/attachment.html>
