[petsc-users] Fwd: Building the same petsc matrix with different numprocs gives different results!
Tue Sep 24 11:03:13 CDT 2013
On Tue, Sep 24, 2013 at 8:35 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
> On Tue, Sep 24, 2013 at 8:41 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Sep 24, 2013 at 8:08 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
>>> On Tue, Sep 24, 2013 at 1:42 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> Analabha Roy <hariseldon99 at gmail.com> writes:
>>>> > Hi all,
>>>> > Compiling and running this
>>>> > code<
>>>> https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c
>>>> >that
>>>> > builds a petsc matrix gives different results when run with different
>>>> > number of processors.
>>> Thanks for the reply.
>>>>  Uh, if you call rand() on different processors, why would you expect
>>>> it
>>>> to give the same results?
>>>> Right, I get that. The rand() was a placeholder.
>>> This original much larger code<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c>replicates the same loop structure and runs the same Petsc subroutines, but
>>> running it by
>>> mpirun -np $N ./eth -lattice_size 5 -vector_size 1 -repulsion 0.0
>>> -draw_out -draw_pause -1
>>> with N=1,2,3,4 gives different results for the matrix dumped out by
>>> lines 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>.
>>> The matrix itself is evaluated in parallel, created in lines 263-275
>>> <https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#263>and
>>> evaluated in lines 294-356<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#294>
>>> (you can click on the line numbers above to navigate directly to them)
>>> Here is a sample <http://i43.tinypic.com/zyhf2f.jpg> of the output of
>>> lines 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>  for N=1,2,3,4 procs left to right.
>>> Thty're different for different procs. They should be the same, since
>>> none of my input parameters are numprocs dependent, and I don't explicitly
>>> use the size or rank anywhere in the code.
>> You are likely not dividing the rows you loop over so you are redundantly
>> computing.
> Line 274<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#274>gets the local row indices of Petsc Matrix
> AVG_BDIBJ
> Line 295
> <https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#295>iterates
> over the local rows and the lines below get the column
> elements. For each row, the column elements are assigned by the lines up
> to  Line 344<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#344>and stored locally in colvalues[]. Dunno if the details are relevant.
> Line 347<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#347>inserts the sitestride1^th row into the matrix
> Line 353+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#353>does the mat assembly
> Then, after a lot of currently irrelevant code,
> Line 514+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>dumps the mat plot to graphics
> Different numprocs give different matrices.
> Can somebody suggest what  I did wrong (or didn't do)?
Different values are being given to MatSetValues() for different numbers of
processes. So
  1) Reduce this to the smallest problem size possible
  2) Print out all rows/cols/values for each call
  3) Compare 2 procs to the serial case
    Matt
>>    Matt
>>>> for (sitestride1 = Istart; sitestride1 < Iend; sitestride1++)
>>>>       for (sitestride2 = 0; sitestride2 < matsize; sitestride2++)
>>>>           for (alpha = 0; alpha < dim; alpha++)
>>>>               for (mu = 0; mu < dim; mu++)
>>>>                 for (lambda = 0; lambda < dim; lambda++)
>>>>                     vecval = rand () / rand ();
>>>>               VecSetValue (BDB_AA, alpha, vecval, INSERT_VALUES);
>>>>           VecAssemblyBegin (BDB_AA);
>>>>           VecAssemblyEnd (BDB_AA);
>>>>           VecSum (BDB_AA, &element);
>>>>           colvalues[sitestride2] = element;
>>>>       //Insert the array of colvalues to the sitestride1^th row of H
>>>>       MatSetValues (AVG_BDIBJ, 1, &sitestride1, matsize, idx, colvalues,
>>>>                     INSERT_VALUES);
>>>> > The code is large and complex, so I have created a smaller program
>>>> > with the same
>>>> > loop structure here. <http://pastebin.ca/2457643>
>>>> > Compile it and run it with "mpirun -np $N ./test -draw_pause -1" gives
>>>> > different results for different values of N even though it's not
>>>> supposed
>>>> > to.
>>>> What do you expect to see?
>>>> > Here is a sample output <http://i42.tinypic.com/2s16ccw.jpg> for
>>>> N=1,2,3,4
>>>> > from left to right.
>>>> > Can anyone guide me as to what I'm doing wrong? Are any of the petssc
>>>> > routines used not parallelizable?
>>>> > Thanks in advance,
>>>> > Regards.
>>>> > *Analabha Roy*
>>>> > C.S.I.R <http://www.csir.res.in>  Senior Research
>>>> > Associate<http://csirhrdg.res.in/poolsra.htm>
>>>> > Saha Institute of Nuclear Physics <http://www.saha.ac.in>
>>>> > Section 1, Block AF
>>>> > Bidhannagar, Calcutta 700064
>>>> > India
>>>> > *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
>>>> > *Webpage*: http://www.ph.utexas.edu/~daneel/
>>> *Analabha Roy*
>>> C.S.I.R <http://www.csir.res.in>  Senior Research Associate<http://csirhrdg.res.in/poolsra.htm>
>>> Section 1, Block AF
>>> India
>> experiments lead.
>> -- Norbert Wiener
> *Analabha Roy*
> Section 1, Block AF
> India
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130924/bb054254/attachment.html>
