[petsc-users] Fwd: Building the same petsc matrix with different numprocs gives different results!
Analabha Roy hariseldon99 at gmail.com
Tue Sep 24 10:35:38 CDT 2013
On Tue, Sep 24, 2013 at 8:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 24, 2013 at 8:08 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
>> On Tue, Sep 24, 2013 at 1:42 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Analabha Roy <hariseldon99 at gmail.com> writes:
>>> > Hi all,
>>> > Compiling and running this
>>> > code<
>>> https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c
>>> >that
>>> > builds a petsc matrix gives different results when run with different
>>> > number of processors.
>> Thanks for the reply.
>>>  Uh, if you call rand() on different processors, why would you expect it
>>> to give the same results?
>>> Right, I get that. The rand() was a placeholder.
>> This original much larger code<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c>replicates the same loop structure and runs the same Petsc subroutines, but
>> running it by
>> mpirun -np $N ./eth -lattice_size 5 -vector_size 1 -repulsion 0.0
>> -draw_out -draw_pause -1
>> with N=1,2,3,4 gives different results for the matrix dumped out by lines
>> 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>.
>> The matrix itself is evaluated in parallel, created in lines 263-275
>> <https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#263>and
>> evaluated in lines 294-356<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#294>
>> (you can click on the line numbers above to navigate directly to them)
>> Here is a sample <http://i43.tinypic.com/zyhf2f.jpg> of the output of
>> lines 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>  for N=1,2,3,4 procs left to right.
>> Thty're different for different procs. They should be the same, since
>> none of my input parameters are numprocs dependent, and I don't explicitly
>> use the size or rank anywhere in the code.
> You are likely not dividing the rows you loop over so you are redundantly
> computing.
Line 274<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#274>gets
the local row indices of Petsc Matrix
AVG_BDIBJ
Line 295
<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#295>iterates
over the local rows and the lines below get the column
elements. For each row, the column elements are assigned by the lines up
to  Line 344<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#344>and
stored locally in colvalues[]. Dunno if the details are relevant.
Line 347<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#347>inserts
the sitestride1^th row into the matrix
Line 353+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#353>does
the mat assembly
Then, after a lot of currently irrelevant code,
Line 514+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>dumps
the mat plot to graphics
Different numprocs give different matrices.
Can somebody suggest what  I did wrong (or didn't do)?
>    Matt
>>> for (sitestride1 = Istart; sitestride1 < Iend; sitestride1++)
>>>       for (sitestride2 = 0; sitestride2 < matsize; sitestride2++)
>>>           for (alpha = 0; alpha < dim; alpha++)
>>>               for (mu = 0; mu < dim; mu++)
>>>                 for (lambda = 0; lambda < dim; lambda++)
>>>                     vecval = rand () / rand ();
>>>               VecSetValue (BDB_AA, alpha, vecval, INSERT_VALUES);
>>>           VecAssemblyBegin (BDB_AA);
>>>           VecAssemblyEnd (BDB_AA);
>>>           VecSum (BDB_AA, &element);
>>>           colvalues[sitestride2] = element;
>>>       //Insert the array of colvalues to the sitestride1^th row of H
>>>       MatSetValues (AVG_BDIBJ, 1, &sitestride1, matsize, idx, colvalues,
>>>                     INSERT_VALUES);
>>> > The code is large and complex, so I have created a smaller program
>>> > with the same
>>> > loop structure here. <http://pastebin.ca/2457643>
>>> > Compile it and run it with "mpirun -np $N ./test -draw_pause -1" gives
>>> > different results for different values of N even though it's not
>>> supposed
>>> > to.
>>> What do you expect to see?
>>> > Here is a sample output <http://i42.tinypic.com/2s16ccw.jpg> for
>>> N=1,2,3,4
>>> > from left to right.
>>> > Can anyone guide me as to what I'm doing wrong? Are any of the petssc
>>> > routines used not parallelizable?
>>> > Thanks in advance,
>>> > Regards.
>>> > *Analabha Roy*
>>> > C.S.I.R <http://www.csir.res.in>  Senior Research
>>> > Associate<http://csirhrdg.res.in/poolsra.htm>
>>> > Saha Institute of Nuclear Physics <http://www.saha.ac.in>
>>> > Section 1, Block AF
>>> > Bidhannagar, Calcutta 700064
>>> > India
>>> > *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
>>> > *Webpage*: http://www.ph.utexas.edu/~daneel/
>> *Analabha Roy*
>> C.S.I.R <http://www.csir.res.in>  Senior Research Associate<http://csirhrdg.res.in/poolsra.htm>
>> Section 1, Block AF
>> India
> experiments lead.
> -- Norbert Wiener
*Analabha Roy*
Section 1, Block AF
India
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130924/fd2f600b/attachment-0001.html>
