[petsc-users] Writing VTK output for vectors derived from DM Global vector
Mon Sep 23 17:30:30 CDT 2013
Garnet Vaz <garnet.vaz at gmail.com> writes:
> Hi,
> I would like to write out my solution to a VTK file where I use unstructured
> grids in DMPlex.
> The solution corresponds to  harmonic frequencies (~ 5-10 distinct) which
> are
> currently saved into a Vec* object. These vectors were created by
> duplicating the
> global vector for the DM object. (I know that they correspond to the right
> cell.)
> Is it possible to have one file which would contain the mesh from the DM
> object and all the Vec* objects?
> Would I have to clone the original DM and use
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerVTKAddField.html
> to include all the vectors?
This is a private function.
> In the above function does
> PetscViewerVTKWriteFunction
> just need to be
> myWriteFunc(vec,viewer)
> VecView(vec,viewer)
> if I do not need to make any changes to the vector?
This should work, but you may want to use PetscObjectSetName() so that
the names of the different fields are sensible.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130923/e7d47757/attachment.pgp>
