[petsc-users] Strange efficiency in PETSc-dev using OpenMP
Sun Sep 22 11:53:04 CDT 2013
1)      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
    Never time without optimization, it can give very misleading information because different parts of the code speedup very differently when optimized
2) Where are the 4 MPI processes being placed on your system? Are they being placed on 4 cores on the same CPU (as with the OpenMP run) or possibly on different CPUs?
3) Do you have any OpenMP pragmas in your code. Make a run where you take them all out
4) Both runs are actually taking very little time in the solver;
  KSPSolve               1 1.0 9.2897e-002
KSPSolve               1 1.0 2.9056e-001
   How are you getting your matrix? From a file?
   Barry
On Sep 21, 2013, at 11:06 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Shri,
> Thanks for your info. It can work with the option -threadcomm_type openmp. But another problem arises, as described as follows.
> The sparse matrix is  53760*53760 with 1067392 non-zero entries. If the codes is compiled using PETSc-3.4.2, it works fine, the equations can be solved quickly and I can see the speedup. But if the code is compiled using PETSc-dev with OpenMP option, it takes a long time in solving the equations and I cannot see any speedup when more processors are used.
> For PETSc-3.4.2,  run by "mpiexec -n 4 ksp_inhm_d -log_summary log_mpi4_petsc3.4.2.log", the iteration and runtime are:
> Iterations     6 time_assembly  0.4137E-01 time_ksp  0.9296E-01
> For PETSc-dev,  run by "mpiexec -n 1 ksp_inhm_d -threadcomm_type openmp -threadcomm_nthreads 4 -log_summary log_openmp_petsc_dev.log", the iteration and runtime are:
> Iterations     6 time_assembly  0.3595E+03 time_ksp  0.2907E+00
> Most of the time 'time_assembly  0.3595E+03' is spent on the following codes
>                 do i = istart, iend - 1
>                    ii = ia_in(i+1)
>                    jj = ia_in(i+2)
>                    call MatSetValues(a, ione, i, jj-ii, ja_in(ii:jj-1)-1, a_in(ii:jj-1), Insert_Values, ierr)
>                 end do
> The log files for both PETSc-3.4.2 and PETSc-dev are attached.
> Is there anything wrong with my codes or with running option? The above codes works fine when using MPICH.
> Thanks and regards,
> Danyang
> On 21/09/2013 2:09 PM, Shri wrote:
>> There are three thread communicator types in PETSc. The default is "no thread" which is basically a non-threaded version. The other two types are "openmp" and "pthread". If you want to use OpenMP then use the option -threadcomm_type openmp.
>> Shri
>> On Sep 21, 2013, at 3:46 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> Hi Barry,
>>> Thanks for the quick reply.
>>> After changing
>>> #if defined(PETSC_HAVE_PTHREADCLASSES) || defined (PETSC_HAVE_OPENMP)
>>> to
>>> and comment out
>>> #elif defined(PETSC_HAVE_OPENMP)
>>> PETSC_EXTERN PetscStack *petscstack;
>>> It can be compiled and validated with "make test".
>>> But I still have questions on running the examples. After rebuild the codes (e.g., ksp_ex2f.f), I can run it with "mpiexec -n 1 ksp_ex2f", or "mpiexec -n 4 ksp_ex2f", or "mpiexec -n 1 ksp_ex2f -threadcomm_nthreads 1", but if I run it with "mpiexec -n 1 ksp_ex2f -threadcomm_nthreads 4", there will be a lot of error information (attached).
>>> The codes is not modified and there is no OpenMP routines in it. For the current development in my project, I want to keep the OpenMP codes in calculating matrix values, but want to solve it with PETSc (OpenMP). Is it possible?
>>> Thanks and regards,
>>> Danyang
>>> On 21/09/2013 7:26 AM, Barry Smith wrote:
>>>>   Danyang,
>>>>      I don't think the  || defined (PETSC_HAVE_OPENMP)   belongs in the code below.
>>>> /*  Linux functions CPU_SET and others don't work if sched.h is not included before
>>>>     including pthread.h. Also, these functions are active only if either _GNU_SOURCE
>>>>     or __USE_GNU is not set (see /usr/include/sched.h and /usr/include/features.h), hence
>>>>     set these first.
>>>> Edit include/petscerror.h and locate these lines and remove that part and then rerun make all.  Let us know if it works or not.
>>>>    Barry
>>>> i.e. replace
>>>> with
>>>> On Sep 21, 2013, at 6:53 AM, Matthew Knepley
>>>> <petsc-maint at mcs.anl.gov>
>>>>  wrote:
>>>>> On Sat, Sep 21, 2013 at 12:18 AM, Danyang Su <danyang.su at gmail.com>
>>>>>  wrote:
>>>>> Hi All,
>>>>> I got error information in compiling petsc-dev with openmp in cygwin. Before, I have successfully compiled petsc-3.4.2 and it works fine.
>>>>> The log files have been attached.
>>>>> The OpenMP configure test is wrong. It clearly fails to find pthread.h, but the test passes. Then in petscerror.h
>>>>> we guard pthread.h using PETSC_HAVE_OPENMP. Can someone who knows OpenMP fix this?
>>>>>     Matt
>>>>> Thanks,
>>>>> Danyang
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>> <error.txt>
> <log_mpi4_petsc3.4.2.log><log_openmp_petsc_dev.log>
