[petsc-users] Strange efficiency in PETSc-dev using OpenMP
Danyang Su danyang.su at gmail.com
Sat Sep 21 23:06:07 CDT 2013
Hi Shri,
Thanks for your info. It can work with the option -threadcomm_type
openmp. But another problem arises, as described as follows.
The sparse matrix is  53760*53760 with 1067392 non-zero entries. If the
codes is compiled using PETSc-3.4.2, it works fine, the equations can be
solved quickly and I can see the speedup. But if the code is compiled
using PETSc-dev with OpenMP option, it takes a long time in solving the
equations and I cannot see any speedup when more processors are used.
For PETSc-3.4.2,  run by "mpiexec -n 4 ksp_inhm_d -log_summary
log_mpi4_petsc3.4.2.log", the iteration and runtime are:
Iterations     6 *time_assembly 0.4137E-01* time_ksp  0.9296E-01
For PETSc-dev,  run by "mpiexec -n 1 ksp_inhm_d -threadcomm_type openmp
-threadcomm_nthreads 4 -log_summary log_openmp_petsc_dev.log", the
Iterations     6 *time_assembly 0.3595E+03* time_ksp  0.2907E+00
Most of the time *'time_assembly 0.3595E+03*' is spent on the following
codes
                 do i = istart, iend - 1
                    ii = ia_in(i+1)
                    jj = ia_in(i+2)
                    call MatSetValues(a, ione, i, jj-ii,
ja_in(ii:jj-1)-1, a_in(ii:jj-1), Insert_Values, ierr)
                 end do
The log files for both PETSc-3.4.2 and PETSc-dev are attached.
Is there anything wrong with my codes or with running option? The above
codes works fine when using MPICH.
Thanks and regards,
Danyang
On 21/09/2013 2:09 PM, Shri wrote:
> There are three thread communicator types in PETSc. The default is "no
> thread" which is basically a non-threaded version. The other two types
> are "openmp" and "pthread". If you want to use OpenMP then use the
> option -threadcomm_type openmp.
> Shri
> On Sep 21, 2013, at 3:46 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>> Hi Barry,
>> Thanks for the quick reply.
>> After changing
>> /#if defined(PETSC_HAVE_PTHREADCLASSES) || defined (PETSC_HAVE_OPENMP) /
>> to
>> /#if defined(PETSC_HAVE_PTHREADCLASSES)/
>> and comment out
>> /#elif defined(PETSC_HAVE_OPENMP)//
>> //PETSC_EXTERN PetscStack *petscstack;/
>> It can be compiled and validated with "make test".
>> But I still have questions on running the examples. After rebuild the
>> codes (e.g., ksp_ex2f.f), I can run it with "mpiexec -n 1 ksp_ex2f",
>> or "mpiexec -n 4 ksp_ex2f", or "mpiexec -n 1 ksp_ex2f
>> -threadcomm_nthreads 1", but if I run it with "mpiexec -n 1 ksp_ex2f
>> -threadcomm_nthreads 4", there will be a lot of error information
>> (attached).
>> The codes is not modified and there is no OpenMP routines in it. For
>> the current development in my project, I want to keep the OpenMP
>> codes in calculating matrix values, but want to solve it with PETSc
>> (OpenMP). Is it possible?
>> Thanks and regards,
>> Danyang
>> On 21/09/2013 7:26 AM, Barry Smith wrote:
>>>    Danyang,
>>>       I don't think the  || defined (PETSC_HAVE_OPENMP)   belongs in the code below.
>>> /*  Linux functions CPU_SET and others don't work if sched.h is not included before
>>>      including pthread.h. Also, these functions are active only if either _GNU_SOURCE
>>>      or __USE_GNU is not set (see /usr/include/sched.h and /usr/include/features.h), hence
>>>      set these first.
>>> Edit include/petscerror.h and locate these lines and remove that part and then rerun make all.  Let us know if it works or not.
>>>     Barry
>>> i.e. replace
>>> with
>>> On Sep 21, 2013, at 6:53 AM, Matthew Knepley<petsc-maint at mcs.anl.gov>  wrote:
>>>> On Sat, Sep 21, 2013 at 12:18 AM, Danyang Su<danyang.su at gmail.com>  wrote:
>>>> Hi All,
>>>> I got error information in compiling petsc-dev with openmp in cygwin. Before, I have successfully compiled petsc-3.4.2 and it works fine.
>>>> The log files have been attached.
>>>> The OpenMP configure test is wrong. It clearly fails to find pthread.h, but the test passes. Then in petscerror.h
>>>> we guard pthread.h using PETSC_HAVE_OPENMP. Can someone who knows OpenMP fix this?
>>>>      Matt
>>>> Thanks,
>>>> Danyang
>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> -- Norbert Wiener
>> <error.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130921/eddc727a/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130921/eddc727a/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130921/eddc727a/attachment-0003.obj>
