[petsc-users] make all freezes
Tue Sep 17 11:09:38 CDT 2013
This doesn't make any sense..
If the build is hanging - we'd like to know exactly where its hanging.
[perhaps copy/paste]
If the run is hanging - we'd like to see the stack trace [via gdb] of the
location of the hang.
xorg-devel should'nt make a difference [from what we know]..
Satish
On Tue, 17 Sep 2013, Analabha Roy wrote:
> Update again:
>  On a hunch, I went to a non-graphical tty where compilation worked! So I
> installed all xorg-devel packages from repository and now compilation seems
> to be working.
> Guess it just needed those...
> Thanks.
> On Tue, Sep 17, 2013 at 1:24 PM, Analabha Roy <hariseldon99 at gmail.com>wrote:
> > Update: Purging openmpi and reinstalling did not work. "make all" in
> > $PETSC_DIR still freezes.
> > On Tue, Sep 17, 2013 at 11:17 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
> >> Hi,
> >> Sorry for the late reply
> >> On Mon, Sep 16, 2013 at 7:03 PM, Matthew Knepley <knepley at gmail.com>wrote:
> >>> On Mon, Sep 16, 2013 at 1:18 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
> >>>> Hi,
> >>>>  I just got a new laptop and installed linux mint KDE. Details below:
> >>>> samsung NP300E5X-U01IN:
> >>>> Kernel 3.8.0-26-generic #38-Ubuntu SMP
> >>>> Four Intel Unknown 800MHz processors, 16760.20 total bogomips, 3733M RAM
> >>>> System library 2.17.0
> >>>> I tried to compile petsc-3.4.2 with the following configuration
> >>>> ./configure --with-scalar-type=complex --with-c2html=0
> >>>> --with-debugging=no --with-fortran-kernels=1 --with-hdf5=yes
> >>>> --with-hdf5-dir=/usr --enable-parallel
> >>>> The configure log is posted here<https://dl.dropboxusercontent.com/u/2769707/configure.log>(dropbox)
> >>>> The configure script seems to run okay, but running "make
> >>>> PETSC_DIR=/usr/local/src/petsc-3.4.2 PETSC_ARCH=arch-linux2-c-opt all" or
> >>>> "make all" causes the compile to hang with no output.
> >>> This sounds like a CMake problem on your machine. Please try running
> >>>   make all-legacy
> >>> although it seems like your Builder run succeeded.
> >> I purged cmake using apt-get and reinstalled it from scratch. The problem
> >> persists
> >> I also ran "make all-legacy". Same problem. No output. Just hangs.
> >>> Downgrading to a previous version of petsc does not seem to help. The
> >>>> problem persists. Using default options "./configure
> >>>> --with-scalar-type=complex" doesn;t seem to change anything either.
> >>>> Running ./config/builder.py works, but then "make test" hangs
> >>>> similarly, as does running make on any example or any of my petsc sources.
> >>> This is different. It is likely that your MPI is not setup correctly to
> >>> launch on this machine. Can you
> >>> run any MPI job?
> >> Yes. Both this hello world example<http://www.dartmouth.edu/~rc/classes/intro_mpi/hello_world_ex.html>and this calculation
> >> of pi<http://www.mcs.anl.gov/research/projects/mpi/usingmpi/examples/simplempi/cpi_c.htm>compiles without errors and runs as expected.
> >> Should I try purging openmpi and reinstalling?
> >>>    Thanks,
> >>>       Matt
> >>>>  Thanks in advance,
> >>>> *Analabha Roy*
> >>>> C.S.I.R <http://www.csir.res.in>  Senior Research Associate<http://csirhrdg.res.in/poolsra.htm>
> >>>> Saha Institute of Nuclear Physics <http://www.saha.ac.in>
> >>>> Section 1, Block AF
> >>>> Bidhannagar, Calcutta 700064
> >>>> India
> >>>> *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
> >>>> *Webpage*: http://www.ph.utexas.edu/~daneel/
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which their
> >>> experiments lead.
> >>> -- Norbert Wiener
> >> *Analabha Roy*
> >> Section 1, Block AF
> >> India
> > *Analabha Roy*
> > Section 1, Block AF
> > India
