[petsc-users] GAMG and linear elasticity
Tabrez Ali stali at geology.wisc.edu
Sun Sep 1 11:38:47 CDT 2013
Its Paraview.
On 09/01/2013 11:12 AM, Umut Tabak wrote:
> On 09/01/2013 06:01 PM, Tabrez Ali wrote:
>> Mark/Umut
>> Here's the code http://defmod.googlecode.com/
>> If you have PETSc installed with METIS then you can build the
>> executable simply by running "make all PETSC_DIR=/home/user/petsc"
>> The three meshes that I am testing GAMG on are available at
>> http://www.geology.wisc.edu/~stali/defmod/gamg_test_input_files.tar.gz
> Thanks for this information, BTW, is that software you are using for
> visualization is Mayavi2?
